virtual dj mapping ...
virtual dj mapping control instinct
i tried to map my controler to virtual dj. i couold pretty much configure everything except for the pitch button.
i cant control the value of the pitch that increases or decreases. its too much. i want it to go slower & value change should be less. i cant figure it out.
can anyone please help me with this??
I meant the paddle for the pitch control
puedes pasarme un lnk kon el mapeo,o decirme como lo as echo...ami no me funciona la mayoria de los botones
CAN YOU PLEASE TRANSLATE? I CAN ONLY UNDERSTAND ENGLISH.
You know a mapping for Virtual DJ is available from the Support site ?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=306&cid=10
As for the beahvior of the pitch controls, you can also modify the repeat fequency and delay from the DJ Control panel in the Advanced tab.
