winding problem rmx...
winding problem rmx console
hello!
i have the new dj console hercules rmx and i have a big problem with it.
when using the virtualdj djc edition, pressing the back and forward wind/skip button nearly at the same time or at the same time makes my vdj going crazy. the used player(in which i wind the track) didnt stop winding at all. when i restart the program(vdj djc edition) its normal again.
can anyone try it out if im the only one with this problem???
i have tried different computers(laptop acer 5710z with vista 32 and my working pc with xp sp2) and another console in a dj shop. same problem!!!
hercules support didnt know this problem at all.
thanks for reading and helping πŸ™‚
dj m2u
maybe its just a bug,
but why would you want to do that anyway?
hello dj m2u,
it is a bug a virtualdj djc 5.0.7, it is corrected in virtualdj djc 5.1 and 5.2 updates.
you can download free updates of virtualdj djc 5 on http://www.virtualdj.com/download/updates.html , you just have to create an account on virtualdj website with the serial number sticked on your cd enveloppe to access to virtualdj free update service.
todays last version of virtualdj djc 5 is virtualdj djc 5.2.
thanks a lot! that was the problem. i was looking daily for updates but just on hercules.com for support, where they wrote that there will never be an update for the vdj djc edition.
p.s. i didnt want to do that anyway but if it happened for any reason accidentally, the party would be stopped for a minute πŸ˜‰
hello dj m2u,
all updates of virtualdj are on http://www.virtualdj.com website, not on hercules website.
Maybe it's just a bug,
Hello DJ M2U,
It is a bug a VirtualDJ DJC 5.0.7, it is corrected in VirtualDJ DJC 5.1 and 5.2 updates.
You can download free updates of VirtualDJ DJC 5 on http://www.virtualdj.com/download/updates.html , you just have to create an account on VirtualDJ website with the serial number sticked on your CD enveloppe to access to VirtualDJ free update service.
Today's last version of VirtualDJ DJC 5 is VirtualDJ DJC 5.2.
Thanks a lot! That was the problem. I was looking daily for updates but just on Hercules.com for support, where they wrote that there will never be an update for the VDJ DJC Edition.
P.S. I didn't want to do that anyway but if it happened for any reason accidentally, the party would be stopped for a minute πŸ˜‰
Hello DJ M2U,
All updates of VirtualDJ are on http://www.virtualdj.com website, not on Hercules website.
