djusting tempo range beyond +/- 8%
3 Users
 Can I  adjust tempo range beyond +/- 8% on a Hercules inpulse 200 mk2 ? thanks 🙂
Topic Tags
It depends on your DJ app.
In Djuced, you can click on the screen on the tempo figure (with a %) written on top of the fader on Djuced screen to change the tempo range between 6%, 8%, 10%,12%,16%, 20%, 25%, 33%, 50% and 100%.
Serato DJ Lite needs a dedicated button to change the tempo range and there is not such a button on DJControl Inpulse 200/200 MK2, so you cannot change the tempo range.
Serato DJ Lite & Pro also include a function which is not tempo range but lets you move the tempo fader to reach any tempo.
If you want to reach a tempo which is out of your range, for example reach +15% BPM while your range is -/+8%,
1) set the deck in Sync mode (Sync button lit)
2) Press the Shift button down, and hold it down,
3) Move the tempo fader in the opposite direction of the direction you want to reach (for exemple, to reach +15%, move your tempo to Minus direction, as if you wanted to do -8%)
4) Release the Shift button: the BPM has not changed on Serato, but the controller tempo fader has moved, so if the BPM says 0% BPM change and your controller fader is full on top (-8%), then when you move your tempo fader from top to bottom, you can reach +16%.
Thanks' for the info that helps me lots 🙂
There's an easier way -> simply press [shift] + [assist / prep]
The more you know!
