Jog wheels stuck and one tighter than another
9 Users
6 Reactions
Hello all!
I'm experiencing problems with jog wheels, they are almost stuck and only spinning around 1 quarter applying enough force . I've read all the old posts in the archive (applied all the suggestions without luck) and I kindly ask if somebody can explain me the jog wheel friction update process. The unit is out of warranty.
Bets regards
Rob
1
Hello Rob5,
I have sent you on the forum private messaging page a guideline to update the friction.
You can read your private message in going on your profile page and clicking on Messages tab.
Please make sure the unit is out of warranty before starting any disassembling.
I you decide to remove the e-clip, I suggest you put a tape on the spring and another on the e-clip since, as both are tiny parts which may jump out when you remove the e-clip, it would be a pity to lose one of these parts.
The wetransfer link I have sent you to download lasts only 3 days.
Thank You!! It's been helpful!   🙂
1
Hello Rob5,
You are welcome.
Hello, I have this problem too. Can I get help too?
1
Hello Roj,
Welcome in the community area.
Please have a look in the forum mail box.
Hi all, I have the same problem of tight jogwheels. Any help?
1
Hello HL1474,
Please have a look in the forum mail box of your profile page.
1
Hey, I have a similar problem with the inpulse 500 gold. The JogWheels are very stiff. If you could sent me the guide how to fix this I would much appreaciate it! By the way:
What's stopping you from posting the instructions for everyone to see?
1
Hello Captain Planet,
I send you the access to friction improvement guideline in a private message.
The main reason which has stopped me from posting open instructions everybody has access to is that some other websites used to post direct links to some files I had put for download, but they did not write on their websites the instructions I had written in the forum, so that, while I had insisted on some points to avoid damaging the controllers, some users have followed my guidelines without taking the cautions preventing from bricking the controller firmware.
I have other reasons for not letting files in open access as as
- it lets me send guideline files with no pollution of other instructions for other OS / USB speed / DJ App / driver version / controller,
- it was the way to get rid of some people who decalibrated Hercules DJ controllers units in music stores, thanks to my calibration instructions,
- it is compulsory when we sign non disclosure agreement for some tools / files / process we use for support only.
HO ANCHE IO LO STESSO PROBLEMA
Hello CarSo81,
Welcome in this discussion.
Please confirm
  • your DJ controller is a DJControl Inpulse 500,
  • you have access to the posts sent to you (last year in this discusssion you did not answer to the question)/
Please write in standard size letters (writing full message in capital letters is perceived as shouting)
Yo tengo el mismo problema. Las ruedas van muy duras. A ver si me podéis ayudar. Gracias
Hi all,
I am new here but have same issue - inpulse 500, both jogwheels struggle to move. Any chance for help?
Thank You in advance!
Hola a todos , tengo el mismo problema, me envian por favor como solucionarlo, gracias
