Re mapp Inpulse 500. FX Control, Dry Wet, Banks FX, Macro FX in DJUCED
Hello everyone,
After several hours trying to figure it out, i’d like to share the custom mapping and changes I made for my controller — I hope some of you find it useful!
  • Mic HI knob → Adjusts the last selected effect parameter. Limitation: it only moves whichever effect was last toggled ON/OFF (not all at once).
  • Mic LO knob → Controls the Dry/Wet of both FX banks at the same time.
  • Pads 4 & 8 (in FX mode) → Toggle FX banks ON/OFF on Deck 1 and Deck 2 respectively.
  • Vinyl button → Re-assigned to toggle the Macro FX panel ON/OFF (instead of vinyl mode).
  • Aux Filter knob → Controls the Macro FX Amount level.
Link: removed link
If you want, you can mapping everything that you want. This steps was helpful to me:
1- Use MIDI-OX to mapp the signals that the controller sents to PC
2- Use "Keyboard" in DJUCED to mapp the functions.
With this, you can define your controls and the functions you want them to do. You need to know some programming or go with GPT haha.
I hope this be useful. Regards.
PD: i cant post links, so try to contact me to send you if you want.
This topic was modified 11 months ago by Benja
