Connectivity issues
5 Utilisateurs
19 Vues
Salut
Brand new controller less than 3 months old. Hardley used yet.
I'm having connectivity issues. When powering on the controller the lights flash briefly before flickering a few times then switch off.
I'm using serato and during powering on the controller shows no sign of connectivity.
The controller is connected to pre amped speakers and I can hear the feedback briefly when i switch the controller on and off.
All cables are standard supplied showing no signs of damage.
Would welcome any suggestions?
Tia.
5 réponses
Hi Tia,
Welcome
Please write some basic technical pieces of info as summarized in the message
https://community.hercules.com/community/controllers/guidelines-to-post-messages-in-dj-controllers-area/
for example:
  • système d'exploitation informatique,
  • version of Hercules DJ drivers,
  • version of Serato DJ used on your computer.
If you use Serato DJ Pro, make sure you have activated the Serato DJ Pro upgrade on this computer since DJC Inpulse T7 does not unlock Serato DJ Pro, it is supported in Serato DJ Lite and needs you to upgrade to Serato DJ Pro (and activate the upgrade on the computer) to use Serato DJ Pro at the end of the trial period.
I am having the same issues, controllor only got it in December. Have tried 2 different computers and still nothing When using DJUCED there is no issues. Both systems are windows 11 and i am using Serato Pro. Had been talking to support via email, but haven't heard back in over a week from them. Your request (1084214)
Bonjour Skineb ...,
Bienvenue dans la communauté des utilisateurs.
Sukkerdj avait posé la question la plus importante, mais vous ne fournissez pas de réponse à cette question:
"Si vous utilisez Serato DJ Pro, assurez-vous que vous avez activé la mise à niveau Serato DJ Pro sur cet ordinateur puisque DJC Inpulse T7 ne débloque pas {(5])} DJ Pro, il est pris en charge dans Serato DJ Lite et a besoin pour la mise à niveau sur {([5]) L'ordinateur) à utiliser Serato DJ Pro à la fin de la période d'essai. "
Avez-vous activé Serato DJ Pro sur votre ordinateur?
Voici le processus pour activer Serato DJ Pro.
https://support.serato.com/hc/en-us/articles/227883448-activating-{( ·5:)
I am getting the same issues to the point that reinstalling the driver has to be done inorder for it to function and then when I shut down it happens agasin. I changed 2 different cable and now it will not light up on 2 different computers
Hello Tracksthinkin,
Bienvenue sur le forum.
Please precise
  • your computer operating system (let's assume it is Windows 11)
  • your DJ app version: if it is Serato, is it Serato DJ Lite or Serato DJ Pro, and which version, 4.0.7 or an older release
In case your DJ app is Serato DJ Pro, please confirm
  • either a a Serato DJ Pro upgrade licence is activated in your Serato account on this computer,
  • or, if you use Serato DJ pro trial, you are still in the 14-day trial period.
as the DJ controller being not be detected in Serato DJ Pro is normal if no Serato DJ Pro upgrade licence is activated on this computer.
