Simultaneous blueto...
Simultaneous bluetooth connections
Hello, I am aware that Dj Control Mix connects via Bluetooth. I would like to know if I can connect other Bluetooth sources simultaneously. for example headphones and even the audio output.
Hello Emineto,
Yes, DJControl Mix bluetooth connection lets you connect your smartphone/tablet to other bluetooth devices as headphones and speakers.
DJControl Mix bluetooth connection is a Bluetooth LE connection, bluetooth LE pairing it is not done in iOS/Android system settings (as bluetooth audio), but in djay App > Settings > MIDI area.
So do not try to pair DJControl Mix in bluetooth in your smartphone iOS / android Settings > Bluetooth, it is not Bluetooth LE process, do the pairing in djay app, as it is described in the quick start guide
https://ts.hercules.com/download/sound/manuals/DJC_Mix/DJControlMix_QSG.pdf#page=2
and it will not interfere with the bluetooth audio pairing of your smartphone or tablet.
Remark: each time you restart djay app, or each time you wake off djay app, you must pair the DJ controller again.
