Hello there, since i am using a Logitech Lightspeed G733, which is a wireless Headset using a USB-Dongle - is there any way to use this with the Hercules 200 XLR and still control the audio? I dont want to give up the luxury of using wireless headphones just to be able to control every audio layer. As far as i know the Hercules 100 would be able to this.
Thank you in advance!
In the Windows sound settings, more precisely in the settings where you can set the level of micros etc. There you have to switch on monitoring for Creator Channel and route this to your headset.
Well i tried that and got it to work after windows kind of blocked access. So far so good! But i can hear the microphone now too in my headphones, how can i seprate them from the creator-mix?
