Beginner and adviso...
Beginner and advisor on audio headphones
3 Users
Hello.
I'm a beginner in this field, and I'd like to know if this product is compatible with the DT 770 Pro 80 ohm headphones. The Hercules outputs 64 mW stereo into 32 ohms.
Thank you very much for your help.
What exactly would you like to know about the 48-volt phantom power supply? There are microphones that require amplification, i.e., a phantom power supply, such as dynamic microphones, which sound better with phantom power because they are more sensitive.
If it has a jack plug, your headset does. Here is an example of a 3.5 mm jack plug. https://www.idealo.de/preisvergleich/ProductCategory/15256F1798702.html
DT 770 PRO (80 Ohm) (B-Ware) 3.5 mm Straight connection cable with 3.5 mm stereo jack plug and 6.35 mm adapter, so yes, you can, according to the data sheet.
https://www.beyerdynamic.de/p/dt-770-pro-80-ohm-b-ware
Thank you very much for your feedback! What I wanted to know is whether the headphone output can power the headphones, which require 80 ohms.
The xlr200 is powered via USB, so as long as the PC is running, the jack will also be powered, I think internally. That's just my guess, as I'm not an electrician by profession. According to EU regulations, an extra power supply for the headphones should be specified on the device's data sheet, as in your case 70-80 ohms.
The ohm (symbol: Ω, the Greek capital letter omega) is the unit of electrical resistance in the International System of Units (SI). It is named after the German physicist Georg Ohm (1789–1854). Various empirically derived standard units for electrical resistance were developed in connection with early telegraphy, and as early as 1861, the British Association for the Advancement of Science proposed a unit derived from existing units for mass, length, and time that was suitable for practical work.
I just forgot to mention that yesterday.MFG Baumi
quelle
https://en.wikipedia.org/wiki/Ohm?utm_source=chatgpt.com
Hello Bpoppy,
Yes, Stream 200 XLR will support perfectly Beyerdynamic DT 770 Pro.
