Stream 200 XLR not ...
Stream 200 XLR not saving state between shutdowns
3 Users
Hi there.
I really like the XLR 200, but something bothers me.
The panel is connected via usb directly to my pc. When I set values, press buttons (like chaining creator/audience) everything works as expected. When I reboot my setup, these settings are gone. For example chained LED is off and I have to press 3 times to reactivate the LED.
Is this known bug or does it work as designed?
Thanks in advance!
Thank you for pointing this bug.
We take it in account and do our best to solve it quickly
Best Regards,
@SumoBotto A new version will be released soon, and that will fix the problem.
@SumoBotto So is it better now with the update?
Tested with 2.4.6[01.51] and it works bit different:
- LEDs still need to be pushed 3 Times.
-> when I mute all (Red LED) and reboot it starts with muted function, but not a red LED.
Also the Aux sound for audience resets on turning the nob back to 0%
What do you use the aux input for? So I can hear you better?
It is one of my outputs and I have mainly Chrome selected for it. It seems only audience is effected, not creator. Can I upload videos here to show it somehow?
I'll try to replicate that and give it a test run, but I already have an idea of what it might be. I'll let you know once I've tested it for a day.
I've now assigned the aux input to it, so I can control it in Creator and Rules, and also in Public. My question for you now: Did you uninstall the old software and install the new one? Or did you just run an update? If you only ran an update, uninstall the software, restart your computer, and install the new software. Also, uninstall the Herkules driver once, because it will get reinstalled anyway. It should work again after that. For me, after the switch, both panels work independently right away for testing.
I performed the update. Currently on work travel. Will test in about 4 weeks.
