19/02/2026 1:12 pm
Hi, i just received my stream 100,
Plugged in, turn on, dowload the software, start to setup the stream 100, noctices a supperposition bug on the screen, software wants to update the stream 100, update done, stream 100 never turn on again.
I need help please
19/02/2026 7:04 pm
Could it be that the USB was disabled in Device Manager to save power? You have to uncheck the box when configuring the driver. After every update of a Win11 build, it is checked again. Best regards, Baumi
02/03/2026 2:41 pm
Can you try to force the update by pressing know 1 and 4 during USB Plug?
Then start Stream Control -> Settings -> FW Update
