Stream 100 x SteelS...
Stream 100 x SteelSeries Sonar
7 Users
2 Reactions
2
I have recently came across a problem where I believe the drivers of the Stream app are overriding the SteelSeries's Virtual Audio Mixer "Sonar". In the past I used my Stream 100 to control Sonar so that I had physical mixer nobs to adjust on the fly. I can no longer do this now because some how the Stream app is causing two of Sonar's audio channels to be adjusted by the other when both channels have audio outputted through them.
I have already talked with SteelSeries technical support and have done everything on my end to isolate where the problem is coming from. After deleting the Stream app and doing an audio test on those same two Sonar channels it was working as intended. Then after reinstalling the Stream app it broke again.
Hi I have the same Problem at the Moment. What is curios is that it does not belong to all Virtual Audio Channels. I have the Issue with Media, Game and Chat, the Aux Channel does work as intended. Is there any Chance that someone will get into that Issue?
Thanks in Advance.
We cannot reproduce this bug.
Adding Game Channel from Sonar to track number 2 of Stream 100, and Chat Channel from Sonar to track number 3 of Stream 100, there is no issue with the control.
Can you please guide us through the exact journey ?
Thank you.
Hi Damien,
thank you for your answer. I try to explain it as far as possible.
The Issue exists if you have Audio playing on two different Channels, eg. Game Sound on Channel Game and Music on Channel Media in Sonar.
Then if you insert those two Channels in Stream Control and Change the Volume of one of those channel, the whole Audio Volume is edited even if the Channel shows that the Audio is still playing. So if i change Game Volume, Media is also changed without visualy Changing in Stream Control or Sonar. If i mute one of the Channels the whole Audio is muted.
The Chat Channel from Sonar is not affected. If I have Audio Running on Game, Chat and Media and I Mute Media or Game, Chat is playing Audio but the other two not.
The Default Windows Audio Interface is set to Sonar Game like default in Sonar.
Thank you in Advance.
Best regards,
Hi Teufelsente,
Thank you for explaining in details. We can reproduce now.
We will investigate.
Damien
Hi Damien,
thank you for the reply.
I have found another bug regarding that Topic.
If you turn on the Streaming Mode in Sonar, the changes made on the Stream 100 wont do anything at all.
Thank you for your help.
Hi Damien,
Have you found a solution to the problem yet? It's really annoying to own a device I can't use at all. It was too expensive for that.
Thank you in advance.
Best regards,
@Teufelsenter, if I understand you correctly, these are only certain traces, is that right? Have you ever reset the software?
Hi Baumi,
the Only Trace which is not affected is the Chat Trace, every other Trace does not work as expected.
I have done multiple resets, in Sonar, in Hercules Stream even reinstalled Windows. So nothing helps.
It could be a programming error in your software. As I know, the xlr200 is supposed to get an update at the beginning of January. Maybe Hercules will manage to fix the programming error in January as well on xlr100.
I have the same issue. Any solution to this problem?
Thanks in advance.
3bady817 I don't know if the new update is out yet. Can you tell us which version of the software you are using? Which version of Windows?
We are working on a solution to solve this issue.
Stream Control will use another name to identify each Sonar Virtual Audio Device separately.
Would you be interested in participating in the Beta test of the new version?
Thank you for your patience
I would like to participate in the beta.
Is there an approximate date when it will take place?
Baumi
I'm running Software 2.3.8[01.51]. Windows 11 with latest updates.
Olivier
Thanks for the reply. Yes, I would like to participate.
Reagrds,
Page 1 / 2
