dj control mp3 e2 ...
dj control mp3 e2 virtual dj 6 pro
dj control mp3 e2 comes with virtual dj 3 . . but i allready have virtual dj 6 pro and i cant connect dj control mp3 e2 to my virtual dj 6 pro..
..any sugestions?
i have the same problem and  i cannot get my to work neither.
hello,
it is not possible to provide an efficient technical help you if you dont write any technical information, as:
- your computer configuration (pc or mac?, operating system ? for example windows xp 32-bit service pack 3)
- your version of virtualdj 6 pro (virtualdj 6 pro is not the version number: the complete version number is, for example, virtualdj 6.1 pro, or 6.08 pro)
- your version of dj control mp3 e2 drivers (last mac drivers are 2.22, last windows drivers are 2010_hdjs_2)
in your profile, there is an equipment description area, so you should fill this area.
the last version of virtualdj 6 pro is virtualdj 6.1.2 pro, and it fully supports dj control mp3 e2, in mac and pc, so did virtualdj 6.1 pro and 6.0.8 pro.
hi, i have the same problem, im italian;
ive bought a dj control mp3 and 2, but it works only with the version of virtual dj that  was in the box , i had already virtual dj 6 but the  console doesnt turn on with it, my pc is a mac book pro.
in italian
salve, traduco qualora ci fosse qualche italiano a rispondermi, dunque il mio problema vedo che non affligge solo me;
ho comprato una dj console mp3 e 2, ma funziona solo con virtual djc edition o come si chiama !;  io ho virtual dj 6 ma non funge con la console sul mio mac book pro, se invece istallo la console su un windows, nessun problema, pensavo problemi con i drivers, voi che suggerite?
your dj control mp3 e2 is natively supported by virtual dj version 6.02 or superior.
also be sure to install the latest drivers (currently v2.22)
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=61&pid=241&cid=1
it is...myne is working with virtual dj 6 perfect. i have both installed on my computer and no problems for now. everything is working. if you install the drivers corectly and your usb is 2.0 (or high) i dont see reason to not work. i think the console doesent work only with demo product of vdj 6 πŸ™‚ πŸ™‚ πŸ™‚ . btw: update your drivers. that mayd be help
i have installed the last version of drivers from the herclules site but it dont work, may be because, with my mac, i don know how delete the olds drivers and so the new drivers arent not really installed
this is usually not a problem.
can you confirm that is present at it should be, as indicated in this document:
http://ts.hercules.com/faqs/eng/her_eng_00391.pdf
if this is all correct, i would suggest deleting all files related to virtual dj:
- both virtual dj you may have in applications
- the virtual dj folder in documents
- the files called com.atomixproductions.virtualdj.plist and  com.atomixproductions.virtualdj.plist you may have in user > library> preferences
empty the trash can then install virtual dj pro.
