djcontrol instinct ...
djcontrol instinct - midi device not detected
djcontrol instinct - midi device not detected red flashing in djuced (flashes 5 times and then it says ready). however, nothing works.
when i unplug the device and put it back in a different red error message appears, saying cannot intitialize device djcontrol instinct asio
- software installed correctly according to pdf
- series control is working in status bar
- in device manager everything works
- all buttons flash when plugged in, afterwards several buttons have lights
Welcome to the forum.
1) Please precise your version of Djuced and your version of Windows
(as described in  https://www.herculesdjmixroom.com/en-us/forum/en-hardware/028386/ )
2) Please confirm you read a message talking of MIDI device not detected and then what is the complete message?
If you get a message talking of MIDI device not detected, can you
- Close Djuced
- Ppen DJControl Instinct control panel
- Go to the Advanced tab
- check if the MIDI channel is 1?
If it is not Channel 1, switch it to channel 1.
