djuced 3.6.5 and 3....
djuced 3.6.5 and 3.6.6 wont work on pc using asio
hello there
after installing the new version of djuced on two diffrent pcs i could not make it work using asio.
it does work on the windows driver
any suggestions?
Hello Zirkin,
As discussed here https://www.herculesdjmixroom.com/en-us/forum/en-software/028977/ , I do not think the issue you meet is related to Djuced 40 but to a bug in the ASIO driver.
Please check if you get the same issue in ASIO4ALL driver.
Hello
How do I import musics to Djuced 40?
Thanks
Hello mat,
There are 3 ways to import music files to Djuced 40:
1) Drag & drop music files from "Windows Explorer" to Djuced Browser,
2) In Djuced browser, in Folders browser, select in Explorer, double click on it, and browse in your computer up to the folder(s) where your music files are stored, and select the tracks,
3) Or import your tracks in iTunes, you will see them in Djuced 40 browser, in the iTunes section.
