hercules dj console...
hercules dj console mk1 and ultramixer 2
hello all πŸ™‚
i have a hercules dj console mk1 and the dj software ultramixer 2
when i enter ultramixer and choose preferences i choose midi device hercules dj console mk1 and it has a green marker besides it with the word "connected"
but the thing is that the console mouse is only working and nothing else (cant use anything in the console)
is there any specific driver that works with ultramixer? (im using the latest drivers for my console)
thank you for the help
go to the dj console control panel , and be sure to set midi input to dj console buttons. that will tell the program to use the controller portion of the console and not the midi input located on the back of the unit.
thank you for your reply πŸ™‚
i already done that but with no results :s
and you are also using the latest version of ultramixer i presume ( v2.3.7.1)?
can you test the midi functionality of the dj console using the following procedure
http://ts.hercules.com/faqs/eng/her_eng_00302.pdf
note: the procedure is for the dj console mk2, but the principle is the same.
Go to the DJ Console Control Panel , and be sure to set MIDI INPUT to DJ Console Buttons. That will tell the program to use the controller portion of the console and not the MIDI input located on the back of the unit.
Thank you for your reply πŸ™‚
I already done that but with no results :S
And you are also using the latest version of Ultramixer I presume ( v2.3.7.1)?
Can you test the MIDI functionality of the DJ console using the following procedure
NOTE: The procedure is for the DJ Console MK2, but the principle is the same.
