i made some changes to the default mapper for virtual dj 6 with hercules mk2-mp3-rmx-steel, to follow the short list:
v1.0
- ability to change the parameter 1 of effect active, when an audio effect is active the rotation of the jog change this parameter (as on the pioneer cdj-100s), when effect turn back off to the jog function coming back to pitch bend / scratch.
- ability to scroll fast within the track with jog, just press the |< or >| button and rotate the jog.
- possibility to unload the track from the deck, hold on the stop button for more than half a second. (only hercules rmx-steel)
- ability to make "browsing" of the tracks with jogs, simply hold the "cue select" button on the deck and rotate the jog. (no hercules mk2) note: that only works on one deck/jog at one time.
- added the flash buttons play/pause when the song is paused. (no hercules steel)
the mapper that you have downloaded it to overwrite in the old path c:documents and settingsxxxmy documentsvirtualdjmappers (do it with virtual dj closed).
download (only virtual dj pro user) -> http://www.virtualdj.com/addons/8336/hercules_mapper_pack.html
v1.2
- unload the track from the deck change button, hold on the load button (not stop) for more than half a second
- added hercules hdjc(mk1) mapper with same modification of mp3
v1.1
- added blink on fx and loop leds when fx or loop are activated (only hercules mp3-mk2)
v1.0
- ability to change the parameter 1 of effect active, when an audio effect is active the rotation of the jog change this parameter (as on the pioneer cdj-100s), when effect turn back off to the jog function coming back to pitch bend / scratch (no hercules steel).
- added blink on play/pause buttons when the song is paused. (no hercules steel)
the mapper that you have downloaded it to unzipped and overwrite in the old path
c:documents and settingsuser namemy documentsvirtualdjmappers (do it with virtual dj closed).
download -> http://www.virtualdj.com/addons/8336/hercules_mapper_pack.html/a >
v1.3
- hercules rmx & steel code updated for v6.0.2
hi cioce, i bought a new hercules steel en registered an account on virtualdj.com
but when i want to download the nwe mappings i get this error:
your current licenses do not allow you to download tools
do you know where i can find a new hercules djconsole steel mapping.xml mapping file?
many thanks,
rick
sorry but you need to have the virtual dj 6.0.2 pro version and not the free le version coming in the steel pack.
v1.4
- added new hercules mp3 e2 mapper with same modification of mp3 plus an advance configuration of the 4+4 buttons
more info about new mp3 e2 -> http://www.hercules.com/uk/dj-music/bdd/p/110/dj-control-mp3-e2/
v1.2
- Unload the track from the deck change button, hold on the load button (not stop) for more than half a second
- Added Hercules HDJC(MK1) mapper with same modification of MP3
v1.1
- Added blink on Fx and Loop leds when Fx or Loop are activated (Only Hercules MP3-MK2)
v1.0
- Ability to change the parameter 1 of effect active, when an audio effect is active the rotation of the Jog change this parameter (as on the Pioneer CDJ-100s), when effect turn back off to the Jog function coming back to Pitch Bend / Scratch (No Hercules Steel).
- Ability to scroll fast within the track with Jog, just press the |< or >| button and rotate the Jog.
- Possibility to unload the track from the deck, hold on the stop button for more than half a second. (Only Hercules RMX-Steel)
- Ability to make "browsing" of the tracks with jogs, simply hold the "Cue Select" button on the deck and rotate the Jog. (No Hercules MK2)
Note: that only works on one deck/jog at one time.
- Added blink on Play/Pause buttons when the song is paused. (No Hercules Steel)
The mapper that you have downloaded it to unzipped and overwrite in the old path
C:\Documents and Settings\User Name\My Documents\VirtualDJ\Mappers (do it with Virtual DJ closed).
Download -> http://www.virtualdj.com/addons/8336/Hercules_Mapper_Pack.html
v1.3
- Hercules RMX & Steel code updated for v6.0.2
Hi cioce, i bought a new hercules steel en registered an account on virtualdj.com
But when I want to download the nwe mappings i get this error:
Your current licenses do not allow you to download Tools
Do you know where I can find a new Hercules DJConsole STEEL mapping.xml mapping file?
many thanks,
Rick
Sorry but you need to have the Virtual DJ 6.0.2 PRO version and not the FREE LE version coming in the Steel pack.
v1.4
- Added new Hercules MP3 e2 mapper with same modification of MP3 plus an advance configuration of the 4+4 buttons
Download ->
More info about new MP3 e2 -> http://www.hercules.com/uk/DJ-Music/bdd/p/110/dj-control-mp3-e2/
