hercules mk2 w/ pro...
hercules mk2 w/ pro version vdj problems
i had the limited version of vdj working perfect with the mk2. i purchased the pro version and now everything is up and running but the headphone switch doesnt work properly now. ive tried several ideas and nothing has worked. please give me any ideas, this really sucks after i paid for the pro version and now its giving me problems!!
im using a macbook 2.4 (updated leopard)
mk2
dj matt
hello dj matt,
please precise what you mean by "the headphones switch doesnt work properly".
if you mean that the headphones output doesnt respect the position of your headphones mode switch, then check in
- virtualdj pro config
- options
the auto-cue setting is disabled (if the auto-cue setting is enabled, virtualdj pro automatically set as cue the deck on which you have loaded the last track.
i`d try following:
virtual dj config > sound cards > outputs: headphones πŸ˜‰
Hello DJ Matt,
Please precise what you mean by "the headphones switch doesn't work properly".
If you mean that the headphones output doesn't respect the position of your headphones mode switch, then check in
- VirtualDJ Pro Config
- Options
the Auto-Cue setting is disabled (if the Auto-Cue setting is enabled, VirtualDJ Pro automatically set as Cue the deck on which you have loaded the last track.
i`d try following:
