is there some predictive mapping out traktor scratch pro 2.5.1? ive got the mapping from the old version, but it did not work in traktor 2.5.1. thank you.
Hello !
I have no issues with the latest mapping for the Air and TraktorPro 2.5.1
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=287&cid=10
Are you sure you have correctly installed it ?
What is not working ?
I installed normally, did the same installation procedure for the traktor 2.1 that I had, but did not work in 2.5, which is not working is that the program is not run in traktor, nothing moves.
When you open traktor, have this settings ?
Check the IN/OUT midi port !
It's working like a charm here.
And in the Hercules Control Panel, the Midi Channel must be 1 (by default it is)
