problem when closin...
problem when closing djuced
hi, when i use djuced and then close the app my trash fills up with two files: config_back_2023_09_26.xml and djuced_back_2023_09_26.db is there a way to avoid this?
Hello Alby,
The folder
My Documents/DJUCED/backup
contains backups of Djuced config and database files.
Once it reaches 5 files, Djuced deletes older versions when closing.
I have sent a suggestion to Djuced team to delete the 6th backup file in a silent suppress (not showing it in the bin).
Ok but what do I do now? If the Djuced team will fix this I won't see the files in the bin anymore?
Yes, once Djuced developpers fix it, the 6th back up file(s) will still be deleted at the end of Djuced session, but you will not see it in the bin.
Ok thank you!
