problems connecting...
problems connecting rmx console to traktor pro
my new rmx console works fine thru the provided vdj but when i run it thru traktor pro with the provided midi mappings for the rmx console i encounter the following problems;
the headphones dont work
only the left deck outputs music
the crossfader doesnt work
the beatmatch and fx buttons seem to work ok for the left deck.
i am new to traktor and currently finding it hard to work out :-).
i bought the remix console to use speciifcally with traktor and find vdj too unreliable.
anyone know why it wont connect properly?
i have powered speakers connected to outputs 1-2
thanks in advance.
im working to the traktor pro e using on 100% very nice !
thanks for the config πŸ™‚
on dj itech
i got the same problem, but with a twist.  i followed the pdf instructions and installed the new driver software package i found on ts hercules website. went thru all the steps, and imported the tsi file for traktor scratch pro.
all i get on my console is a pitch reset and sync light that is steadily on.  none of the dial or joggers work, nor does any of the load buttons.
im runnig this on my laptop which is a compaq persario, with 2 gigs of ram.  i also hooked up my controller to a belkin usb hub with a power supply to correct any low power voltages that might come up with my laptop. per the instruction in the pdf.
ive also tried to use the controller on my desktop pc, using a rear mounted usb port, vice a front or hub. and get the same ouytcome.
am i missing anything else here to do???
can you test the rmx as a midi controller as described in this document:
are every controls working correctly?
i used midi monitor and all the controls do work. they go from 0 to 127 as described in the pdf file. so i know that
the controller is active when that app is running.
thanks in advance.
im having pretty much the same problem. have just set up traktor pro with hercules steel. the cross-fader wont work and the track will load on deck b and play but cant be heard. any advice? ive been through the pdf and checked that ive set this up in the right manner, but i am new to traktor so would appreciate any advice. thanks
hello,
please check if you have activated internal mixing in traktor pro, it looks like if you are in external mode.
hi,
how do i check whether ive activated internal/ external mixing?
edit: just to update, the play button on deck a doesnt elicit a response now. also, if the answer to the above is just to adjust view options, then ive played around with this on each of the four settings but with no change to the problems described. but, being new to this im sure i may be missing something.
second edit: ive worked out where i could switch the internal mixing (in the output routing menu). everything appears to be working well apart from when i move the cross-fader, it also moves the track selector up and down, as if i was using the arrow keys to scan up and down the track list. any remedy for this?
hello,
please precise
- which version of traktor pro you use (for example 1.2.7),
- in which environment (for example mac os 10.6.6 or windows 7 64-bit),
- with which dj console series driver (for 2010 hdjs 4 in windows, or driver 2.47 in mac os).
if you use traktor pro 1.2 or after, please confirm you have loaded the tsi file for traktor 1.2 (for mac, file   tp_dj_stl(mac)_v1.2.tsi / for windows, file tp_dj_stl(pc)_v1.2.tsi) rather than the tsi for traktor pro 1.12 (file tp_dj_stl_v1.tsi).
hi, im using:
traktor pro 1.2.7
mac 10.6.6
driver 2.47
ive loaded in the traktor 1.2 tsi file
after a little more experimenting, these are the problems im getting:
- the crossfader works as a cross fader, but also scrolls through the track collection
- the pitch control for deck a doesnt work for pitch but instead moves the crossfader
- movement of deck a adjusts the deck a mid setting
- movement of deck b adjusts the deck a treble setting
- the apply ctrl. on switch works, but also toggles bass min/max on deck a
- gain for deck a also adjusts volume for deck b
there may well be other issues, but im a newbie on traktor and am only just beginning to experiment.
as indicated in the document that is included with the profile, youve loaded the tsi in traktor using the import button, correct ?
if you go to controller-manager > device menu, you should normally have 2 choices:
- generic keyboard
- generic midi (dj control steel)
is that the cases ?
do you have any other entry (i.e. profile) that could potentially create conflicts ?
if so, select the said profile so it appears in the device field, then from the edit... menu, select delete.
ive been away awhile so has taken me some time to reply. the problem is now solved. deleting redundant general midi profile was all that was needed. all seems to be working ok now. thanks for your support dj phatso.
Should I assume that your configured Traktor (Audio and MIDI) as indicated in the PDF document included with the MIDI profile ?
im working to the traktor PRO e using on 100% very nice !
on DJ ITech
I got the same problem, but with a twist.  I followed the pdf instructions and installed the new driver software package I found on TS Hercules website. Went thru all the steps, and imported the TSI file for Traktor Scratch Pro.
All I get on my console is a Pitch Reset and Sync light that is steadily on.  None of the dial or joggers work, nor does any of the load buttons.
I'm runnig this on my laptop which is a Compaq Persario, with 2 gigs of ram.  I also hooked up my controller to a Belkin USB Hub with a power supply to correct any low power voltages that might come up with my laptop. Per the instruction in the pdf.
I've also tried to use the controller on my desktop pc, using a rear mounted USB port, vice a front or hub. And get the same ouytcome.
Am I missing anything else here to do???
Can you test the Rmx as a MIDI controller as described in this document:
Are every controls working correctly?
I used Midi Monitor and all the controls do work. They go from 0 to 127 as described in the PDF file. So I know that
My new rmx console works fine thru the provided vdj but when I run it thru traktor pro with the provided midi mappings for the rmx console I encounter the following problems;
I am new to traktor and currently finding it hard to work out :-).
I bought the remix console to use speciifcally with traktor and find vdj too unreliable.
I have powered speakers connected to outputs 1-2
Thanks in advance.
I'm having pretty much the same problem. Have just set up Traktor Pro with Hercules Steel. The cross-fader won't work and the track will load on Deck B and play but can't be heard. Any advice? I've been through the pdf and checked that I've set this up in the right manner, but I am new to Traktor so would appreciate any advice. Thanks
Please check if you have activated internal mixing in Traktor Pro, it looks like if you are in external mode.
How do I check whether I've activated internal/ external mixing?
EDIT: Just to update, the Play button on Deck A doesn't elicit a response now. Also, if the answer to the above is just to adjust View options, then I've played around with this on each of the four settings but with no change to the problems described. But, being new to this I'm sure I may be missing something.
SECOND EDIT: I've worked out where I could switch the internal mixing (in the Output Routing menu). Everything appears to be working well apart from when I move the cross-fader, it also moves the track selector up and down, as if I was using the arrow keys to scan up and down the track list. Any remedy for this?
Please precise
- which version of Traktor Pro you use (for example 1.2.7),
- in which environment (for example Mac OS 10.6.6 or Windows 7 64-bit),
- with which DJ Console series driver (for 2010 HDJS 4 in Windows, or driver 2.47 in Mac OS).
If you use Traktor Pro 1.2 or after, please confirm you have loaded the TSI file for Traktor 1.2 (for Mac, file   TP_DJ_STL(MAC)_v1.2.TSI / for Windows, file TP_DJ_STL(PC)_v1.2.tsi) rather than the TSI for Traktor Pro 1.12 (file TP_DJ_STL_v1.tsi).
Hi, I'm using:
Traktor Pro 1.2.7
Mac 10.6.6
Driver 2.47
I've loaded in the Traktor 1.2 TSI file
After a little more experimenting, these are the problems I'm getting:
- The Crossfader works as a cross fader, but also scrolls through the track collection
- The Pitch Control for Deck A doesn't work for Pitch but instead moves the Crossfader
- Movement of Deck A adjusts the Deck A Mid setting
- Movement of Deck B adjusts the Deck A Treble setting
- The Apply Ctrl. on switch works, but also toggles Bass min/max on Deck A
- Gain for Deck A also adjusts Volume for Deck B
There may well be other issues, but I'm a newbie on Traktor and am only just beginning to experiment.
As indicated in the document that is included with the profile, you've loaded the TSI in Traktor using the IMPORT button, correct ?
If you go to Controller-Manager > Device menu, you should normally have 2 choices:
- Generic Keyboard
- Generic MIDI (DJ Control Steel)
Is that the cases ?
Do you have any other entry (i.e. profile) that could potentially create conflicts ?
If so, select the said profile so it appears in the Device field, then from the Edit... menu, select Delete.
I've been away awhile so has taken me some time to reply. The problem is now solved. Deleting redundant General MIDI profile was all that was needed. All seems to be working ok now. Thanks for your support DJ Phatso.
Page 2 / 2
