problems installing...
problems installing hercules steel
first off, hello, im new here. i am having problems installing my hercules steel. when i go to my device manager to see if computer is recognizing the steel i get a code 1 not congigured correctly and device cannot start code 10. i am not very good with computers and anyones help would be so helpful right now. thanks for the time!
have you tried installing your console using the latest driver update ?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=61&pid=226&cid=1
be sure to strictly follow this installation procedure:
http://ts.hercules.com/download/sound/txt/dj_series_installation_pc_en.pdf
i have tried what you suggested and i also keep getting,"the software you are installing for this hardware and something about microsoft windows logo and do i want to continue, i continue and the bulk hercules steel drivers installation fails. has anyone else had this problem?  i have had no luck installing this thing. please help! thanks!
Have you tried installing your console using the latest driver update ?
Be sure to strictly follow this installation procedure:
I have tried what you suggested and I also keep getting,"The software you are installing for this hardware and something about Microsoft Windows logo and Do I want to continue, I continue and the bulk hercules steel drivers installation fails. Has anyone else had this problem?  I have had no luck installing this thing. Please Help! Thanks!
