i have traktor pro 2.0.1 and i want to use it with my mk4. i have downloaded the tsi file "[traktor pro/duo 2]", everything works except the jog.
i later found that i had to download instead "[traktor pro/duo]" ("at least version 1.2.7").. i have downloaded that file, but a window showed me that that file doesnt exist or it is corrupted -.-
does anyone know if i can download this file from somewhere else?
or if there is some other way?
thanks! and sorry for my english not very correct!
As indicated on the download page, the TSI file for Traktor 2 requires that you run version 2.12 or superior. This explains why it will not work correctly with previous version such as v2.01.
Update your version of Traktor (currently 2.6.4) and you will be able to the TSI file and your console.
Ok thank you! Can i do the update from the official site without paying?
If you have a registered version of Traktor 2, all updates related to that version are free.
My traktor 2.0.1 is cracked! there are problems?
Native Instruments obviously will not provide you with an update if you didn't purchase it.
goood
1) You can use the old TSI file for Traktor Pro/Duo, it still works in Traktor Pro 2.
2) You have no reason not to buy Traktor Pro 2 license if you need it, as Traktor Pro 2 license cost is reasonable (UDS 99).
