rmx console - usb d...
rmx console - usb device not recognized
hi guys.
so my friend gave me his hercules dj console rmx because he couldnt figure out how to fix it when his laptop wouldnt recognize it.
he had it working properly for a few months and when he got a new laptop it didnt work for him, so when im trying to connect it now on my laptop it doesnt work either.
when i connect it, the console lights flash blue on and off and i get an error message saying my usb device has malfunctioned and is not recognized. yes i tried different usb ports.
any suggestions?
The first suggestion is to precise
- your operating system version (for example Windows 8.1 64-bit)
- your computer (brand, model, CPU, RAM, USB 2.0 or USB 3.0 port)
- which Hercules drivers you gave installed (for example 2014_HDJS_1).
I have Windows 7 professional, and I'm on a Dell Inspiron 3542.
When I put my disc in to install the software/drivers, at one point it is waiting on me to connect my device but since it doesn't recognize it, it doesn't install properly. I get the DJ icon but it has a red X over it.
Have you tried connecting a powered USB hub (hub with a power adapter) between the computer and the DJ Console Rmx?
yes I just fixed it by using a USB hub. thanks!
You are welcome.
