hi all.
i have a dj console mk4 which i use with traktor pro on a mbp. works perfect ! also in os x lion for normal sound it shows up.
but i also tried to use it as a audio interface only for cubase & live and they dont recognise it as an audio deviece.
anybody any idea ?
cheers
If it works for Traktor, then there is no reason for the MK4 not to work for other softwares.
As long as it recognized by the operating system correctly:
I use Live all the time, so I can assure you that it is not a problem. Hercules DJ Console MK4 (4 In, 4 Out) should be available for both Audio Input and Ouput Device.
As for Cubase. It's been a while, but I see no reasons why it wouldn't work.
