virtual dj 5.2 help...
virtual dj 5.2 help no sound in deck 2 when crossfade
ive been having problems with virtual dj 5.2 and rmx console.  when i play 1st deck and use the crossfader to play 2nd deck no sond comes through the speakers.
configuration:  inputs: none
                      output: external mixer
                      soundcard: 4-out controller
                      driver: hercules dj console
                      outputs left deck chan 1& 2/right deck: chan 3 & 4
ive updated all the software as i have snow leopard for macbook pro. 10.6.6
im just going off memory here but isnt it out but 1 &2 supposed to be  on the same channel and 3&4 left out for other sources.
what do you mean redskyy?
ive plugged my speakers through into the external mixer in channel 1?
here is some more information:
           &nbs p;          output: external mixer
           &nbs p;          soundcard: 4-out controller
           &nbs p;          driver: hercules dj console
           &nbs p;          outputs left deck chan 1& 2/right deck: chan 3 & 4
ive updated all the software as i have snow leopard for macbook pro. 10.6.6.
heres some more information:
in system preferences, sound it says:
play sound effects through hercules rmx console
output: hercules dj console rmx
input: hercules dj rmx aggregate
in applications, utlities, audiomidi setup:
hercules dj console rmx (use this sound for output)            m     (volume is min)  value _blank_  db_(blank)
4 in /4 out        1: ... (volume max)   value  1.00  db 0.00
        2: ... (voume max)   value 1.00 db 0.00
        3. ... (volume max) value 0.99 db -0.50
        4. ... (volume max) value 0.99 db -0.50
configure speakers: multi-channel quadraphonic 1 , 2, 3, 4
hercules dj console rmx aggregate (use this sound for input)   use            audio device                     in  out
4 in / 4 out        box ticked   hercules dj console rmx   4    4
configure speakers: quadraphobic, multi channel 1, 2, 3, 4
help, djing in 5 days!
i am now gettting sound out of my left speakers and not my right, but when i cross fade the music is changing to each deck. i plugged my headphones in channel 4 of the rmx console and the right deck is playing in my headphones but not the right speaker? both speakers are fine when i play the cd separate and our correctly wired up.
confirguration is now:
inputs: none
outputs: headphones
soundcard: 4 out card
driver 1: hearcules console rmx
otput channels: master chanel 1 & 2 headphones channel 3 &4
i am now gettting sound out of my left external speakers and not my right, but when i cross fade the music from left to right deck on virtual dj, the music is only playing and mixing in my left external speakers?. i plugged my headphones in channel 4 of the rmx console and the right deck is playing in my headphones but not the right speaker? both speakers are fine when i play the cd separate and our correctly wired up.
inputs: none
outputs: headphones
