Need calibration Guide for Inpulse 500
22 Users
3 Reactions
as some of my EQ knobs don't match with the knobs position shown in DJUCED f.e., i want to try to recalibrate them. AFAIK there is a guide how to do it. Can someone please send me the guide?
Thanx!
This topic was modified 2 years ago by AZ
Hello, i would also need the calibration guide for my inpulse 500 controller. I use Windows 10.
Two of my EQ knobs on Desk 2 do not show the correct setting at 12 o'clock position.
Hello DDDDEETTTT,
I have sent you a message on the private messaging area with a link to the calibration guide.
It will remain online for 1 week.
Bonjour
J'ai besoin du guide de calibration également.
Inpulse 500
Windows 11
Bonjour DJ Wallace,
Pour savoir si le guide de calibration vous sera(it) utile, jai besoin de 2 informations:
1) avez-vous testé dans Djuced si la/les position(s) d'un ou plusieurs contrôles ne correspond pas à la/les positions qu'affiche Djuced pour ces fonctions. Si oui, quel(s) contrôle(s) ?
2) avez vous testé, sur Chrome sur https://www.midimonitor.com/ avec le contrôleur connecté, si le contrôleur envoie tout seul (sans que vous le touchiez) des flux de données ou non ?  Si oui, ça bloquerait la calibration.
Sorry to jump on a post but I could do with the calibration guide please.
Nearly impossible to get the gains right.
Turn the gain knob very very slightly and it either jumps into the red or down really low, does it when moving the gain knob a millimeter left or right, so it's not big adjustments that make it change so massively.
Pretty sure it's not a latency issue as all other controls/knobs are spot on and where they should be.
Cheers guys.
I will need the calibration guide too for my Inpulse 500 on Windows 11, HI and FX on deck 1, Bass on deck 2 are no longer acurate.  According to the midi monitor, nothing move when I touch nothng.
Thank you
Hi, I would also need a copy of calibration guide for my inpulse 500 controller. One of my Low EQ knob on deck 2 does not function well. I use Windows 11. Thanks!
Page 3 / 3
