Inpulse T7 headphone output stops when Cue/Mix is moved or Master Cue is pressed
3 Users
1 Reactions
1
I am experiencing a reproducible headphone-output issue with a new Hercules DJControl Inpulse T7 on my main Windows 11 laptop.
Problem description
When I first installed the controller and Serato DJ Pro on my main laptop, everything worked correctly for approximately two to three hours.
The problem then appeared suddenly. Since then, it has remained permanently reproducible on this computer.
After restarting the controller, the headphone output initially works normally. However, the headphone audio disappears completely as soon as I:
  • Move the Cue/Mix rotary control, even by a very small amount
  • Press the Master Cue/headphone button
The position of the Cue/Mix control does not matter. The issue is triggered by changing its position. It happens whether the control starts fully on Cue, in the centre or fully on Mix.
Once the problem has been triggered, moving the control back to its previous position does not restore the audio. Switching the Master Cue button off again also does not restore it.
The headphone output only works again after restarting the controller.
After the audio disappears, a very faint background hiss or hum remains audible in the headphones. It sounds as though the headphone amplifier is still powered, but the actual audio signal is no longer being routed to it.
Controller and MIDI tests
I tested the controls in the Hercules Control Panel.
  • The Cue/Mix rotary control is detected correctly
  • The Master Cue button is detected correctly
  • The MIDI test shows green activity
  • The Master Cue button correctly switches on and off in the test
  • The LED on the Master Cue button also switches on and off normally
  • There are no obvious missing, stuck or incorrect control signals
The physical controls therefore appear to function correctly. The problem seems to occur when the controller processes the Cue/Mix or Master Cue command within the headphone-audio routing.
Software tests on the affected computer
The issue occurs with:
  • Serato DJ Pro 4.0.9, latest available version
  • DJUCED 6.6.3, latest available version
  • DJUCED using DJControl Inpulse T7 ASIO
  • DJUCED using Speakers – DJControl Inpulse T7, WASAPI
  • The Hercules Control Panel audio test
The problem therefore does not appear to be limited to Serato DJ Pro or only to the ASIO driver.
Test on a second computer
I also tested the same controller and the same headphones on an older HP Envy dv7 notebook.
This older computer is close to its performance limit when running Serato DJ Pro with the Inpulse T7. Serato regularly lags, freezes or does not operate smoothly on this computer.
Despite these performance problems, the following functions work correctly on the older HP Envy dv7:
  • Headphone output
  • Cue/Mix rotary control
  • Master Cue button
Moving the Cue/Mix control or pressing Master Cue does not cause the headphone output to fail on the older computer.
I therefore want to use my newer and more powerful HP Spectre as my main DJ computer. However, the headphone-routing problem currently makes this impossible.
Main computer specifications
  • HP Spectre x360 Convertible 15-eb1xxx
  • Windows 11 Pro 64-bit
  • Windows version 25H2
  • Windows build 10.0.26200
  • Intel Core i7-1165G7
  • 4 cores and 8 logical processors
  • 16 GB RAM
  • BIOS AMI F.19, dated 17 April 2025
  • UEFI BIOS mode
  • Secure Boot enabled
  • Thunderbolt 4
  • Intel Iris Xe Graphics
Relevant audio and USB drivers
  • DJControl Inpulse T7 driver: 6.0.8.0
  • Hercules USB audio driver file: HDJusbaudioks_x64.sys
  • Intel Smart Sound Technology for USB Audio: 10.29.0.5938
  • Realtek High Definition Audio: 6.0.9205.1
  • Thunderbolt controller driver: 1.41.1094.0
  • Thunderbolt NVM firmware: 46.0
Hercules controller and driver versions
  • Hercules driver package: 1.HDJS.2025
  • Firmware: 1.87
  • TOP: 1.24
  • Driver: 6.0.8.0
  • DLL: 0.4.0.0
  • Control Panel: 2.9.0.0
Troubleshooting already completed
  • Updated Windows
  • Updated the HP BIOS
  • Updated the available HP system drivers
  • Updated graphics, audio and other device drivers
  • Tested the controller through USB-A
  • Tested the controller through USB-C
  • Tested different USB connections
  • Adjusted and disabled USB power-saving settings
  • Used an 8 ms audio buffer
  • Completely uninstalled and reinstalled the Hercules drivers
  • Tested the Hercules 2023 driver package
  • Tested the Hercules 2025 driver package
  • Tested ASIO in DJUCED
  • Tested WASAPI in DJUCED
  • Tested Serato DJ Pro
  • Tested the MIDI controls in the Hercules Control Panel
  • Tested the Hercules Control Panel audio test
  • Tested the controller successfully on a second Windows computer
Questions
Has anyone experienced this exact behaviour with the DJControl Inpulse T7?
Could the problem be related to:
  • Windows 11 25H2
  • The USB or Thunderbolt controller of the HP Spectre
  • Incorrect or incomplete USB-audio device initialisation
  • A conflict between the Hercules driver and another Windows audio component
Are there any additional diagnostic logs, alternative driver configurations, firmware recovery procedures or Windows settings that could help identify the cause?
The fact that the controller originally worked correctly on the HP Spectre for two to three hours, but then suddenly developed this permanent and reproducible problem, may be relevant.
Thank you very much for any assistance.
Additional note regarding official support
I am posting this in the public forum because I have been unable to open a support ticket through the official Hercules support website for several days.
The reCAPTCHA displays the following error:
“Could not connect to the reCAPTCHA service. Please check your internet connection and refresh the page to receive a reCAPTCHA challenge.”
I have tested the support website using several different devices, browsers, internet connections and locations, but the same error continues to appear.
Because of this issue, I cannot create an account or log in to submit an official support request. I have also been unable to find a direct Hercules technical-support email address, and there does not appear to be a Swiss support telephone number.
For these reasons, I am asking for assistance here in the forum.
If when you try to sign in https://support.hercules.com website, you read the message:
Then you have set your settings for Hercules website in a way which refuses the conditions of the reCAPTCHA service.
To change the cookies settings for Hercules websites, please:
1) Customize the cookie settings: click on the green circle with a cookie
2) In the cookie settings menu, accept the "Targeting Cookies" and click on "Save my preferences"
3) Then you can see the reCAPTCHA question: "I'm not a robot" and you can click on it to sign in.
Hello DJGiggola,
We may test your Cue to Mix rotary potentiometer to check it sends the normal command.
If you can
1) close your DJ app,
2) run Google Chrome internet browser
3) Go to a MIDI capture web page, as Midilli Tech Web Tool https://midilli.tech/midi-web-tool/
4) In the MIDI page, Select the T7 as MIDI Input, and click on Connect
5) Then turn the Cue to Mix rotary potentiometer gradually from Cue to Mix and look at the MIDI values look at the B0 05 values, the MSB (Most Significant Byte), and forget the B0 25 values (they are the LSB: Least Significant Byte)
  • If the B0 05 Value grow gradually from 00 on Cue to 7F on Mix, this rotary potentiometer is normal
  • If the B0 05 value has not a gradual curve from 00 to 7F, this rotary potentiometer is not normal
I completed the MIDI test as requested. The B0 05 MSB values increase gradually and continuously from 00 at Cue to 7F at Mix, without any abnormal jumps.
Therefore, the Cue/Mix rotary potentiometer appears to be functioning normally.
Spoiler
Raw Values
Time Type Value Channel Device Raw Message
Hex
19:35:20.447 CC (#5) 0 1 DJControl Inpulse T7 B0 05 00
19:35:20.448 CC (#37) 59 1 DJControl Inpulse T7 B0 25 3B
19:35:20.743 CC (#5) 0 1 DJControl Inpulse T7 B0 05 00
19:35:20.744 CC (#37) 76 1 DJControl Inpulse T7 B0 25 4C
19:35:20.880 CC (#5) 0 1 DJControl Inpulse T7 B0 05 00
19:35:20.882 CC (#37) 102 1 DJControl Inpulse T7 B0 25 66
19:35:20.893 CC (#5) 1 1 DJControl Inpulse T7 B0 05 01
19:35:20.894 CC (#37) 9 1 DJControl Inpulse T7 B0 25 09
19:35:21.097 CC (#5) 1 1 DJControl Inpulse T7 B0 05 01
19:35:21.099 CC (#37) 31 1 DJControl Inpulse T7 B0 25 1F
19:35:21.103 CC (#5) 1 1 DJControl Inpulse T7 B0 05 01
19:35:21.104 CC (#37) 53 1 DJControl Inpulse T7 B0 25 35
19:35:21.136 CC (#5) 1 1 DJControl Inpulse T7 B0 05 01
19:35:21.137 CC (#37) 71 1 DJControl Inpulse T7 B0 25 47
19:35:21.320 CC (#5) 1 1 DJControl Inpulse T7 B0 05 01
19:35:21.322 CC (#37) 92 1 DJControl Inpulse T7 B0 25 5C
19:35:21.341 CC (#5) 1 1 DJControl Inpulse T7 B0 05 01
19:35:21.342 CC (#37) 119 1 DJControl Inpulse T7 B0 25 77
19:35:21.366 CC (#5) 2 1 DJControl Inpulse T7 B0 05 02
19:35:21.367 CC (#37) 21 1 DJControl Inpulse T7 B0 25 15
19:35:21.650 CC (#5) 2 1 DJControl Inpulse T7 B0 05 02
19:35:21.650 CC (#37) 48 1 DJControl Inpulse T7 B0 25 30
19:35:21.663 CC (#5) 2 1 DJControl Inpulse T7 B0 05 02
19:35:21.664 CC (#37) 78 1 DJControl Inpulse T7 B0 25 4E
19:35:21.676 CC (#5) 2 1 DJControl Inpulse T7 B0 05 02
19:35:21.678 CC (#37) 96 1 DJControl Inpulse T7 B0 25 60
19:35:21.866 CC (#5) 2 1 DJControl Inpulse T7 B0 05 02
19:35:21.867 CC (#37) 126 1 DJControl Inpulse T7 B0 25 7E
19:35:21.873 CC (#5) 3 1 DJControl Inpulse T7 B0 05 03
19:35:21.874 CC (#37) 38 1 DJControl Inpulse T7 B0 25 26
19:35:21.997 CC (#5) 3 1 DJControl Inpulse T7 B0 05 03
19:35:21.998 CC (#37) 55 1 DJControl Inpulse T7 B0 25 37
19:35:22.011 CC (#5) 3 1 DJControl Inpulse T7 B0 05 03
19:35:22.015 CC (#37) 73 1 DJControl Inpulse T7 B0 25 49
19:35:22.017 CC (#5) 3 1 DJControl Inpulse T7 B0 05 03
19:35:22.018 CC (#37) 95 1 DJControl Inpulse T7 B0 25 5F
19:35:22.176 CC (#5) 3 1 DJControl Inpulse T7 B0 05 03
19:35:22.176 CC (#37) 112 1 DJControl Inpulse T7 B0 25 70
19:35:22.182 CC (#5) 4 1 DJControl Inpulse T7 B0 05 04
19:35:22.183 CC (#37) 2 1 DJControl Inpulse T7 B0 25 02
19:35:22.197 CC (#5) 4 1 DJControl Inpulse T7 B0 05 04
19:35:22.198 CC (#37) 19 1 DJControl Inpulse T7 B0 25 13
19:35:22.215 CC (#5) 4 1 DJControl Inpulse T7 B0 05 04
19:35:22.216 CC (#37) 37 1 DJControl Inpulse T7 B0 25 25
19:35:22.426 CC (#5) 4 1 DJControl Inpulse T7 B0 05 04
19:35:22.427 CC (#37) 54 1 DJControl Inpulse T7 B0 25 36
19:35:22.439 CC (#5) 4 1 DJControl Inpulse T7 B0 05 04
19:35:22.441 CC (#37) 85 1 DJControl Inpulse T7 B0 25 55
19:35:22.446 CC (#5) 4 1 DJControl Inpulse T7 B0 05 04
19:35:22.448 CC (#37) 115 1 DJControl Inpulse T7 B0 25 73
19:35:22.688 CC (#5) 5 1 DJControl Inpulse T7 B0 05 05
19:35:22.689 CC (#37) 9 1 DJControl Inpulse T7 B0 25 09
19:35:22.701 CC (#5) 5 1 DJControl Inpulse T7 B0 05 05
19:35:22.702 CC (#37) 40 1 DJControl Inpulse T7 B0 25 28
19:35:22.722 CC (#5) 5 1 DJControl Inpulse T7 B0 05 05
19:35:22.724 CC (#37) 57 1 DJControl Inpulse T7 B0 25 39
19:35:22.898 CC (#5) 5 1 DJControl Inpulse T7 B0 05 05
19:35:22.899 CC (#37) 101 1 DJControl Inpulse T7 B0 25 65
19:35:22.907 CC (#5) 5 1 DJControl Inpulse T7 B0 05 05
19:35:22.909 CC (#37) 127 1 DJControl Inpulse T7 B0 25 7F
19:35:23.057 CC (#5) 6 1 DJControl Inpulse T7 B0 05 06
19:35:23.058 CC (#37) 21 1 DJControl Inpulse T7 B0 25 15
19:35:23.083 CC (#5) 6 1 DJControl Inpulse T7 B0 05 06
19:35:23.084 CC (#37) 39 1 DJControl Inpulse T7 B0 25 27
19:35:23.090 CC (#5) 6 1 DJControl Inpulse T7 B0 05 06
19:35:23.091 CC (#37) 61 1 DJControl Inpulse T7 B0 25 3D
19:35:23.233 CC (#5) 6 1 DJControl Inpulse T7 B0 05 06
19:35:23.235 CC (#37) 91 1 DJControl Inpulse T7 B0 25 5B
19:35:23.241 CC (#5) 6 1 DJControl Inpulse T7 B0 05 06
19:35:23.242 CC (#37) 109 1 DJControl Inpulse T7 B0 25 6D
19:35:23.248 CC (#5) 6 1 DJControl Inpulse T7 B0 05 06
19:35:23.249 CC (#37) 126 1 DJControl Inpulse T7 B0 25 7E
19:35:23.280 CC (#5) 7 1 DJControl Inpulse T7 B0 05 07
19:35:23.282 CC (#37) 16 1 DJControl Inpulse T7 B0 25 10
19:35:23.458 CC (#5) 7 1 DJControl Inpulse T7 B0 05 07
19:35:23.459 CC (#37) 33 1 DJControl Inpulse T7 B0 25 21
19:35:23.464 CC (#5) 7 1 DJControl Inpulse T7 B0 05 07
19:35:23.465 CC (#37) 55 1 DJControl Inpulse T7 B0 25 37
19:35:23.478 CC (#5) 7 1 DJControl Inpulse T7 B0 05 07
19:35:23.480 CC (#37) 81 1 DJControl Inpulse T7 B0 25 51
19:35:23.813 CC (#5) 7 1 DJControl Inpulse T7 B0 05 07
19:35:23.814 CC (#37) 99 1 DJControl Inpulse T7 B0 25 63
19:35:23.839 CC (#5) 8 1 DJControl Inpulse T7 B0 05 08
19:35:23.841 CC (#37) 1 1 DJControl Inpulse T7 B0 25 01
19:35:23.852 CC (#5) 8 1 DJControl Inpulse T7 B0 05 08
19:35:23.853 CC (#37) 28 1 DJControl Inpulse T7 B0 25 1C
19:35:23.938 CC (#5) 8 1 DJControl Inpulse T7 B0 05 08
19:35:23.940 CC (#37) 93 1 DJControl Inpulse T7 B0 25 5D
19:35:24.030 CC (#5) 9 1 DJControl Inpulse T7 B0 05 09
19:35:24.031 CC (#37) 5 1 DJControl Inpulse T7 B0 25 05
19:35:24.035 CC (#5) 9 1 DJControl Inpulse T7 B0 05 09
19:35:24.036 CC (#37) 27 1 DJControl Inpulse T7 B0 25 1B
19:35:24.141 CC (#5) 9 1 DJControl Inpulse T7 B0 05 09
19:35:24.142 CC (#37) 44 1 DJControl Inpulse T7 B0 25 2C
19:35:24.168 CC (#5) 9 1 DJControl Inpulse T7 B0 05 09
19:35:24.169 CC (#37) 70 1 DJControl Inpulse T7 B0 25 46
19:35:24.173 CC (#5) 9 1 DJControl Inpulse T7 B0 05 09
19:35:24.175 CC (#37) 97 1 DJControl Inpulse T7 B0 25 61
19:35:24.253 CC (#5) 9 1 DJControl Inpulse T7 B0 05 09
19:35:24.254 CC (#37) 127 1 DJControl Inpulse T7 B0 25 7F
19:35:24.259 CC (#5) 10 1 DJControl Inpulse T7 B0 05 0A
19:35:24.261 CC (#37) 30 1 DJControl Inpulse T7 B0 25 1E
19:35:24.267 CC (#5) 10 1 DJControl Inpulse T7 B0 05 0A
19:35:24.268 CC (#37) 52 1 DJControl Inpulse T7 B0 25 34
19:35:24.331 CC (#5) 10 1 DJControl Inpulse T7 B0 05 0A
19:35:24.333 CC (#37) 87 1 DJControl Inpulse T7 B0 25 57
19:35:24.340 CC (#5) 10 1 DJControl Inpulse T7 B0 05 0A
19:35:24.342 CC (#37) 117 1 DJControl Inpulse T7 B0 25 75
19:35:24.515 CC (#5) 11 1 DJControl Inpulse T7 B0 05 0B
19:35:24.517 CC (#37) 20 1 DJControl Inpulse T7 B0 25 14
19:35:24.530 CC (#5) 11 1 DJControl Inpulse T7 B0 05 0B
19:35:24.532 CC (#37) 59 1 DJControl Inpulse T7 B0 25 3B
19:35:24.576 CC (#5) 11 1 DJControl Inpulse T7 B0 05 0B
19:35:24.577 CC (#37) 77 1 DJControl Inpulse T7 B0 25 4D
19:35:24.590 CC (#5) 11 1 DJControl Inpulse T7 B0 05 0B
19:35:24.592 CC (#37) 112 1 DJControl Inpulse T7 B0 25 70
19:35:24.602 CC (#5) 12 1 DJControl Inpulse T7 B0 05 0C
19:35:24.603 CC (#37) 6 1 DJControl Inpulse T7 B0 25 06
19:35:24.673 CC (#5) 12 1 DJControl Inpulse T7 B0 05 0C
19:35:24.675 CC (#37) 23 1 DJControl Inpulse T7 B0 25 17
19:35:24.693 CC (#5) 12 1 DJControl Inpulse T7 B0 05 0C
19:35:24.697 CC (#37) 58 1 DJControl Inpulse T7 B0 25 3A
19:35:24.726 CC (#5) 12 1 DJControl Inpulse T7 B0 05 0C
19:35:24.728 CC (#37) 76 1 DJControl Inpulse T7 B0 25 4C
19:35:25.029 CC (#5) 12 1 DJControl Inpulse T7 B0 05 0C
19:35:25.030 CC (#37) 93 1 DJControl Inpulse T7 B0 25 5D
19:35:25.041 CC (#5) 13 1 DJControl Inpulse T7 B0 05 0D
19:35:25.043 CC (#37) 5 1 DJControl Inpulse T7 B0 25 05
19:35:25.134 CC (#5) 13 1 DJControl Inpulse T7 B0 05 0D
19:35:25.135 CC (#37) 22 1 DJControl Inpulse T7 B0 25 16
19:35:25.148 CC (#5) 13 1 DJControl Inpulse T7 B0 05 0D
19:35:25.150 CC (#37) 40 1 DJControl Inpulse T7 B0 25 28
19:35:25.153 CC (#5) 13 1 DJControl Inpulse T7 B0 05 0D
19:35:25.159 CC (#37) 61 1 DJControl Inpulse T7 B0 25 3D
19:35:25.168 CC (#5) 13 1 DJControl Inpulse T7 B0 05 0D
19:35:25.170 CC (#37) 83 1 DJControl Inpulse T7 B0 25 53
19:35:25.311 CC (#5) 13 1 DJControl Inpulse T7 B0 05 0D
19:35:25.313 CC (#37) 114 1 DJControl Inpulse T7 B0 25 72
19:35:25.325 CC (#5) 14 1 DJControl Inpulse T7 B0 05 0E
19:35:25.328 CC (#37) 12 1 DJControl Inpulse T7 B0 25 0C
19:35:25.358 CC (#5) 14 1 DJControl Inpulse T7 B0 05 0E
19:35:25.359 CC (#37) 30 1 DJControl Inpulse T7 B0 25 1E
19:35:25.568 CC (#5) 14 1 DJControl Inpulse T7 B0 05 0E
19:35:25.570 CC (#37) 56 1 DJControl Inpulse T7 B0 25 38
19:35:25.590 CC (#5) 14 1 DJControl Inpulse T7 B0 05 0E
19:35:25.597 CC (#37) 91 1 DJControl Inpulse T7 B0 25 5B
19:35:25.733 CC (#5) 14 1 DJControl Inpulse T7 B0 05 0E
19:35:25.735 CC (#37) 108 1 DJControl Inpulse T7 B0 25 6C
19:35:25.903 CC (#5) 15 1 DJControl Inpulse T7 B0 05 0F
19:35:25.908 CC (#37) 11 1 DJControl Inpulse T7 B0 25 0B
19:35:25.917 CC (#5) 15 1 DJControl Inpulse T7 B0 05 0F
19:35:25.918 CC (#37) 42 1 DJControl Inpulse T7 B0 25 2A
19:35:25.976 CC (#5) 15 1 DJControl Inpulse T7 B0 05 0F
19:35:25.979 CC (#37) 59 1 DJControl Inpulse T7 B0 25 3B
19:35:25.982 CC (#5) 15 1 DJControl Inpulse T7 B0 05 0F
19:35:25.984 CC (#37) 77 1 DJControl Inpulse T7 B0 25 4D
19:35:25.993 CC (#5) 15 1 DJControl Inpulse T7 B0 05 0F
19:35:25.997 CC (#37) 107 1 DJControl Inpulse T7 B0 25 6B
19:35:26.061 CC (#5) 16 1 DJControl Inpulse T7 B0 05 10
19:35:26.063 CC (#37) 19 1 DJControl Inpulse T7 B0 25 13
19:35:26.068 CC (#5) 16 1 DJControl Inpulse T7 B0 05 10
19:35:26.070 CC (#37) 45 1 DJControl Inpulse T7 B0 25 2D
19:35:26.140 CC (#5) 16 1 DJControl Inpulse T7 B0 05 10
19:35:26.141 CC (#37) 76 1 DJControl Inpulse T7 B0 25 4C
19:35:26.146 CC (#5) 16 1 DJControl Inpulse T7 B0 05 10
19:35:26.148 CC (#37) 93 1 DJControl Inpulse T7 B0 25 5D
19:35:26.154 CC (#5) 16 1 DJControl Inpulse T7 B0 05 10
19:35:26.159 CC (#37) 124 1 DJControl Inpulse T7 B0 25 7C
19:35:26.259 CC (#5) 17 1 DJControl Inpulse T7 B0 05 11
19:35:26.262 CC (#37) 26 1 DJControl Inpulse T7 B0 25 1A
19:35:26.277 CC (#5) 17 1 DJControl Inpulse T7 B0 05 11
19:35:26.281 CC (#37) 61 1 DJControl Inpulse T7 B0 25 3D
19:35:26.528 CC (#5) 17 1 DJControl Inpulse T7 B0 05 11
19:35:26.531 CC (#37) 79 1 DJControl Inpulse T7 B0 25 4F
19:35:26.545 CC (#5) 17 1 DJControl Inpulse T7 B0 05 11
19:35:26.548 CC (#37) 123 1 DJControl Inpulse T7 B0 25 7B
19:35:26.784 CC (#5) 18 1 DJControl Inpulse T7 B0 05 12
19:35:26.785 CC (#37) 12 1 DJControl Inpulse T7 B0 25 0C
19:35:26.836 CC (#5) 18 1 DJControl Inpulse T7 B0 05 12
19:35:26.837 CC (#37) 34 1 DJControl Inpulse T7 B0 25 22
19:35:26.842 CC (#5) 18 1 DJControl Inpulse T7 B0 05 12
19:35:26.844 CC (#37) 60 1 DJControl Inpulse T7 B0 25 3C
19:35:26.850 CC (#5) 18 1 DJControl Inpulse T7 B0 05 12
19:35:26.858 CC (#37) 78 1 DJControl Inpulse T7 B0 25 4E
19:35:26.994 CC (#5) 18 1 DJControl Inpulse T7 B0 05 12
19:35:26.997 CC (#37) 95 1 DJControl Inpulse T7 B0 25 5F
19:35:27.010 CC (#5) 18 1 DJControl Inpulse T7 B0 05 12
19:35:27.012 CC (#37) 113 1 DJControl Inpulse T7 B0 25 71
19:35:27.026 CC (#5) 19 1 DJControl Inpulse T7 B0 05 13
19:35:27.029 CC (#37) 11 1 DJControl Inpulse T7 B0 25 0B
19:35:27.119 CC (#5) 19 1 DJControl Inpulse T7 B0 05 13
19:35:27.120 CC (#37) 28 1 DJControl Inpulse T7 B0 25 1C
19:35:27.139 CC (#5) 19 1 DJControl Inpulse T7 B0 05 13
19:35:27.142 CC (#37) 50 1 DJControl Inpulse T7 B0 25 32
19:35:27.152 CC (#5) 19 1 DJControl Inpulse T7 B0 05 13
19:35:27.153 CC (#37) 72 1 DJControl Inpulse T7 B0 25 48
19:35:27.179 CC (#5) 19 1 DJControl Inpulse T7 B0 05 13
19:35:27.182 CC (#37) 90 1 DJControl Inpulse T7 B0 25 5A
19:35:27.290 CC (#5) 19 1 DJControl Inpulse T7 B0 05 13
19:35:27.293 CC (#37) 112 1 DJControl Inpulse T7 B0 25 70
19:35:27.297 CC (#5) 20 1 DJControl Inpulse T7 B0 05 14
19:35:27.300 CC (#37) 19 1 DJControl Inpulse T7 B0 25 13
19:35:27.368 CC (#5) 20 1 DJControl Inpulse T7 B0 05 14
19:35:27.370 CC (#37) 36 1 DJControl Inpulse T7 B0 25 24
19:35:27.408 CC (#5) 20 1 DJControl Inpulse T7 B0 05 14
19:35:27.410 CC (#37) 58 1 DJControl Inpulse T7 B0 25 3A
19:35:27.414 CC (#5) 20 1 DJControl Inpulse T7 B0 05 14
19:35:27.417 CC (#37) 75 1 DJControl Inpulse T7 B0 25 4B
19:35:27.425 CC (#5) 20 1 DJControl Inpulse T7 B0 05 14
19:35:27.426 CC (#37) 102 1 DJControl Inpulse T7 B0 25 66
19:35:27.586 CC (#5) 20 1 DJControl Inpulse T7 B0 05 14
19:35:27.595 CC (#37) 119 1 DJControl Inpulse T7 B0 25 77
19:35:27.602 CC (#5) 21 1 DJControl Inpulse T7 B0 05 15
19:35:27.609 CC (#37) 17 1 DJControl Inpulse T7 B0 25 11
19:35:27.619 CC (#5) 21 1 DJControl Inpulse T7 B0 05 15
19:35:27.625 CC (#37) 44 1 DJControl Inpulse T7 B0 25 2C
19:35:27.717 CC (#5) 21 1 DJControl Inpulse T7 B0 05 15
19:35:27.719 CC (#37) 96 1 DJControl Inpulse T7 B0 25 60
19:35:27.731 CC (#5) 21 1 DJControl Inpulse T7 B0 05 15
19:35:27.733 CC (#37) 114 1 DJControl Inpulse T7 B0 25 72
19:35:27.882 CC (#5) 22 1 DJControl Inpulse T7 B0 05 16
19:35:27.883 CC (#37) 3 1 DJControl Inpulse T7 B0 25 03
19:35:27.908 CC (#5) 22 1 DJControl Inpulse T7 B0 05 16
19:35:27.910 CC (#37) 29 1 DJControl Inpulse T7 B0 25 1D
19:35:27.914 CC (#5) 22 1 DJControl Inpulse T7 B0 05 16
19:35:27.916 CC (#37) 47 1 DJControl Inpulse T7 B0 25 2F
19:35:28.020 CC (#5) 22 1 DJControl Inpulse T7 B0 05 16
19:35:28.027 CC (#37) 64 1 DJControl Inpulse T7 B0 25 40
19:35:28.044 CC (#5) 22 1 DJControl Inpulse T7 B0 05 16
19:35:28.049 CC (#37) 117 1 DJControl Inpulse T7 B0 25 75
19:35:28.197 CC (#5) 23 1 DJControl Inpulse T7 B0 05 17
19:35:28.199 CC (#37) 6 1 DJControl Inpulse T7 B0 25 06
19:35:28.203 CC (#5) 23 1 DJControl Inpulse T7 B0 05 17
19:35:28.209 CC (#37) 24 1 DJControl Inpulse T7 B0 25 18
19:35:28.215 CC (#5) 23 1 DJControl Inpulse T7 B0 05 17
19:35:28.218 CC (#37) 46 1 DJControl Inpulse T7 B0 25 2E
19:35:28.220 CC (#5) 23 1 DJControl Inpulse T7 B0 05 17
19:35:28.224 CC (#37) 68 1 DJControl Inpulse T7 B0 25 44
19:35:28.276 CC (#5) 23 1 DJControl Inpulse T7 B0 05 17
19:35:28.279 CC (#37) 85 1 DJControl Inpulse T7 B0 25 55
19:35:28.283 CC (#5) 24 1 DJControl Inpulse T7 B0 05 18
19:35:28.285 CC (#37) 1 1 DJControl Inpulse T7 B0 25 01
19:35:28.519 CC (#5) 24 1 DJControl Inpulse T7 B0 05 18
19:35:28.525 CC (#37) 18 1 DJControl Inpulse T7 B0 25 12
19:35:28.541 CC (#5) 24 1 DJControl Inpulse T7 B0 05 18
19:35:28.545 CC (#37) 45 1 DJControl Inpulse T7 B0 25 2D
19:35:28.548 CC (#5) 24 1 DJControl Inpulse T7 B0 05 18
19:35:28.556 CC (#37) 71 1 DJControl Inpulse T7 B0 25 47
19:35:28.631 CC (#5) 24 1 DJControl Inpulse T7 B0 05 18
19:35:28.633 CC (#37) 88 1 DJControl Inpulse T7 B0 25 58
19:35:28.664 CC (#5) 24 1 DJControl Inpulse T7 B0 05 18
19:35:28.666 CC (#37) 106 1 DJControl Inpulse T7 B0 25 6A
19:35:28.677 CC (#5) 25 1 DJControl Inpulse T7 B0 05 19
19:35:28.679 CC (#37) 9 1 DJControl Inpulse T7 B0 25 09
19:35:28.960 CC (#5) 25 1 DJControl Inpulse T7 B0 05 19
19:35:28.962 CC (#37) 26 1 DJControl Inpulse T7 B0 25 1A
19:35:28.986 CC (#5) 25 1 DJControl Inpulse T7 B0 05 19
19:35:28.993 CC (#37) 44 1 DJControl Inpulse T7 B0 25 2C
19:35:28.995 CC (#5) 25 1 DJControl Inpulse T7 B0 05 19
19:35:28.997 CC (#37) 83 1 DJControl Inpulse T7 B0 25 53
19:35:29.052 CC (#5) 25 1 DJControl Inpulse T7 B0 05 19
19:35:29.054 CC (#37) 105 1 DJControl Inpulse T7 B0 25 69
19:35:29.065 CC (#5) 25 1 DJControl Inpulse T7 B0 05 19
19:35:29.069 CC (#37) 127 1 DJControl Inpulse T7 B0 25 7F
19:35:29.085 CC (#5) 26 1 DJControl Inpulse T7 B0 05 1A
19:35:29.087 CC (#37) 25 1 DJControl Inpulse T7 B0 25 19
19:35:29.328 CC (#5) 26 1 DJControl Inpulse T7 B0 05 1A
19:35:29.330 CC (#37) 42 1 DJControl Inpulse T7 B0 25 2A
19:35:29.354 CC (#5) 26 1 DJControl Inpulse T7 B0 05 1A
19:35:29.360 CC (#37) 69 1 DJControl Inpulse T7 B0 25 45
19:35:29.364 CC (#5) 26 1 DJControl Inpulse T7 B0 05 1A
19:35:29.370 CC (#37) 99 1 DJControl Inpulse T7 B0 25 63
19:35:29.453 CC (#5) 27 1 DJControl Inpulse T7 B0 05 1B
19:35:29.460 CC (#37) 2 1 DJControl Inpulse T7 B0 25 02
19:35:29.467 CC (#5) 27 1 DJControl Inpulse T7 B0 05 1B
19:35:29.470 CC (#37) 37 1 DJControl Inpulse T7 B0 25 25
19:35:29.545 CC (#5) 27 1 DJControl Inpulse T7 B0 05 1B
19:35:29.547 CC (#37) 54 1 DJControl Inpulse T7 B0 25 36
19:35:29.572 CC (#5) 27 1 DJControl Inpulse T7 B0 05 1B
19:35:29.576 CC (#37) 107 1 DJControl Inpulse T7 B0 25 6B
19:35:29.650 CC (#5) 28 1 DJControl Inpulse T7 B0 05 1C
19:35:29.654 CC (#37) 14 1 DJControl Inpulse T7 B0 25 0E
19:35:29.663 CC (#5) 28 1 DJControl Inpulse T7 B0 05 1C
19:35:29.665 CC (#37) 53 1 DJControl Inpulse T7 B0 25 35
19:35:29.860 CC (#5) 28 1 DJControl Inpulse T7 B0 05 1C
19:35:29.862 CC (#37) 75 1 DJControl Inpulse T7 B0 25 4B
19:35:29.875 CC (#5) 29 1 DJControl Inpulse T7 B0 05 1D
19:35:29.878 CC (#37) 0 1 DJControl Inpulse T7 B0 25 00
19:35:30.071 CC (#5) 29 1 DJControl Inpulse T7 B0 05 1D
19:35:30.077 CC (#37) 22 1 DJControl Inpulse T7 B0 25 16
19:35:30.097 CC (#5) 29 1 DJControl Inpulse T7 B0 05 1D
19:35:30.101 CC (#37) 57 1 DJControl Inpulse T7 B0 25 39
19:35:30.176 CC (#5) 29 1 DJControl Inpulse T7 B0 05 1D
19:35:30.186 CC (#37) 83 1 DJControl Inpulse T7 B0 25 53
19:35:30.199 CC (#5) 29 1 DJControl Inpulse T7 B0 05 1D
19:35:30.203 CC (#37) 127 1 DJControl Inpulse T7 B0 25 7F
19:35:30.334 CC (#5) 30 1 DJControl Inpulse T7 B0 05 1E
19:35:30.336 CC (#37) 16 1 DJControl Inpulse T7 B0 25 10
19:35:30.386 CC (#5) 30 1 DJControl Inpulse T7 B0 05 1E
19:35:30.394 CC (#37) 34 1 DJControl Inpulse T7 B0 25 22
19:35:30.399 CC (#5) 30 1 DJControl Inpulse T7 B0 05 1E
19:35:30.403 CC (#37) 51 1 DJControl Inpulse T7 B0 25 33
19:35:30.412 CC (#5) 30 1 DJControl Inpulse T7 B0 05 1E
19:35:30.418 CC (#37) 73 1 DJControl Inpulse T7 B0 25 49
19:35:30.544 CC (#5) 30 1 DJControl Inpulse T7 B0 05 1E
19:35:30.546 CC (#37) 90 1 DJControl Inpulse T7 B0 25 5A
19:35:30.583 CC (#5) 30 1 DJControl Inpulse T7 B0 05 1E
19:35:30.585 CC (#37) 117 1 DJControl Inpulse T7 B0 25 75
19:35:30.592 CC (#5) 31 1 DJControl Inpulse T7 B0 05 1F
19:35:30.594 CC (#37) 11 1 DJControl Inpulse T7 B0 25 0B
19:35:30.649 CC (#5) 31 1 DJControl Inpulse T7 B0 05 1F
19:35:30.651 CC (#37) 28 1 DJControl Inpulse T7 B0 25 1C
19:35:30.662 CC (#5) 31 1 DJControl Inpulse T7 B0 05 1F
19:35:30.667 CC (#37) 46 1 DJControl Inpulse T7 B0 25 2E
19:35:30.669 CC (#5) 31 1 DJControl Inpulse T7 B0 05 1F
19:35:30.670 CC (#37) 89 1 DJControl Inpulse T7 B0 25 59
19:35:30.912 CC (#5) 31 1 DJControl Inpulse T7 B0 05 1F
19:35:30.914 CC (#37) 111 1 DJControl Inpulse T7 B0 25 6F
19:35:30.927 CC (#5) 32 1 DJControl Inpulse T7 B0 05 20
19:35:30.931 CC (#37) 1 1 DJControl Inpulse T7 B0 25 01
19:35:30.943 CC (#5) 32 1 DJControl Inpulse T7 B0 05 20
19:35:30.946 CC (#37) 18 1 DJControl Inpulse T7 B0 25 12
19:35:30.952 CC (#5) 32 1 DJControl Inpulse T7 B0 05 20
19:35:30.955 CC (#37) 36 1 DJControl Inpulse T7 B0 25 24
19:35:31.004 CC (#5) 32 1 DJControl Inpulse T7 B0 05 20
19:35:31.012 CC (#37) 101 1 DJControl Inpulse T7 B0 25 65
19:35:31.109 CC (#5) 33 1 DJControl Inpulse T7 B0 05 21
19:35:31.111 CC (#37) 0 1 DJControl Inpulse T7 B0 25 00
19:35:31.116 CC (#5) 33 1 DJControl Inpulse T7 B0 05 21
19:35:31.118 CC (#37) 21 1 DJControl Inpulse T7 B0 25 15
19:35:31.126 CC (#5) 33 1 DJControl Inpulse T7 B0 05 21
19:35:31.130 CC (#37) 48 1 DJControl Inpulse T7 B0 25 30
19:35:31.182 CC (#5) 33 1 DJControl Inpulse T7 B0 05 21
19:35:31.184 CC (#37) 96 1 DJControl Inpulse T7 B0 25 60
19:35:31.192 CC (#5) 33 1 DJControl Inpulse T7 B0 05 21
19:35:31.194 CC (#37) 113 1 DJControl Inpulse T7 B0 25 71
19:35:31.255 CC (#5) 34 1 DJControl Inpulse T7 B0 05 22
19:35:31.259 CC (#37) 7 1 DJControl Inpulse T7 B0 25 07
19:35:31.261 CC (#5) 34 1 DJControl Inpulse T7 B0 05 22
19:35:31.263 CC (#37) 55 1 DJControl Inpulse T7 B0 25 37
19:35:31.301 CC (#5) 34 1 DJControl Inpulse T7 B0 05 22
19:35:31.303 CC (#37) 86 1 DJControl Inpulse T7 B0 25 56
19:35:31.311 CC (#5) 35 1 DJControl Inpulse T7 B0 05 23
19:35:31.313 CC (#37) 2 1 DJControl Inpulse T7 B0 25 02
19:35:31.353 CC (#5) 35 1 DJControl Inpulse T7 B0 05 23
19:35:31.361 CC (#37) 67 1 DJControl Inpulse T7 B0 25 43
19:35:31.393 CC (#5) 35 1 DJControl Inpulse T7 B0 05 23
19:35:31.398 CC (#37) 89 1 DJControl Inpulse T7 B0 25 59
19:35:31.402 CC (#5) 36 1 DJControl Inpulse T7 B0 05 24
19:35:31.406 CC (#37) 14 1 DJControl Inpulse T7 B0 25 0E
19:35:31.452 CC (#5) 36 1 DJControl Inpulse T7 B0 05 24
19:35:31.460 CC (#37) 62 1 DJControl Inpulse T7 B0 25 3E
19:35:31.462 CC (#5) 36 1 DJControl Inpulse T7 B0 05 24
19:35:31.467 CC (#37) 84 1 DJControl Inpulse T7 B0 25 54
19:35:31.504 CC (#5) 36 1 DJControl Inpulse T7 B0 05 24
19:35:31.520 CC (#37) 114 1 DJControl Inpulse T7 B0 25 72
19:35:31.525 CC (#5) 37 1 DJControl Inpulse T7 B0 05 25
19:35:31.531 CC (#37) 13 1 DJControl Inpulse T7 B0 25 0D
19:35:31.649 CC (#5) 37 1 DJControl Inpulse T7 B0 05 25
19:35:31.653 CC (#37) 30 1 DJControl Inpulse T7 B0 25 1E
19:35:31.689 CC (#5) 37 1 DJControl Inpulse T7 B0 05 25
19:35:31.693 CC (#37) 48 1 DJControl Inpulse T7 B0 25 30
19:35:31.696 CC (#5) 37 1 DJControl Inpulse T7 B0 05 25
19:35:31.699 CC (#37) 65 1 DJControl Inpulse T7 B0 25 41
19:35:31.702 CC (#5) 37 1 DJControl Inpulse T7 B0 05 25
19:35:31.707 CC (#37) 96 1 DJControl Inpulse T7 B0 25 60
19:35:31.774 CC (#5) 37 1 DJControl Inpulse T7 B0 05 25
19:35:31.777 CC (#37) 122 1 DJControl Inpulse T7 B0 25 7A
19:35:31.781 CC (#5) 38 1 DJControl Inpulse T7 B0 05 26
19:35:31.785 CC (#37) 16 1 DJControl Inpulse T7 B0 25 10
19:35:31.795 CC (#5) 38 1 DJControl Inpulse T7 B0 05 26
19:35:31.799 CC (#37) 38 1 DJControl Inpulse T7 B0 25 26
19:35:31.853 CC (#5) 38 1 DJControl Inpulse T7 B0 05 26
19:35:31.861 CC (#37) 55 1 DJControl Inpulse T7 B0 25 37
19:35:31.866 CC (#5) 38 1 DJControl Inpulse T7 B0 05 26
19:35:31.876 CC (#37) 108 1 DJControl Inpulse T7 B0 25 6C
19:35:31.965 CC (#5) 38 1 DJControl Inpulse T7 B0 05 26
19:35:31.968 CC (#37) 125 1 DJControl Inpulse T7 B0 25 7D
19:35:31.976 CC (#5) 39 1 DJControl Inpulse T7 B0 05 27
19:35:31.980 CC (#37) 45 1 DJControl Inpulse T7 B0 25 2D
19:35:32.097 CC (#5) 39 1 DJControl Inpulse T7 B0 05 27
19:35:32.099 CC (#37) 63 1 DJControl Inpulse T7 B0 25 3F
19:35:32.110 CC (#5) 39 1 DJControl Inpulse T7 B0 05 27
19:35:32.114 CC (#37) 80 1 DJControl Inpulse T7 B0 25 50
19:35:32.118 CC (#5) 39 1 DJControl Inpulse T7 B0 05 27
19:35:32.124 CC (#37) 115 1 DJControl Inpulse T7 B0 25 73
19:35:32.222 CC (#5) 40 1 DJControl Inpulse T7 B0 05 28
19:35:32.226 CC (#37) 5 1 DJControl Inpulse T7 B0 25 05
19:35:32.228 CC (#5) 40 1 DJControl Inpulse T7 B0 05 28
19:35:32.230 CC (#37) 31 1 DJControl Inpulse T7 B0 25 1F
19:35:32.235 CC (#5) 40 1 DJControl Inpulse T7 B0 05 28
19:35:32.243 CC (#37) 62 1 DJControl Inpulse T7 B0 25 3E
19:35:32.281 CC (#5) 40 1 DJControl Inpulse T7 B0 05 28
19:35:32.285 CC (#37) 119 1 DJControl Inpulse T7 B0 25 77
19:35:32.334 CC (#5) 41 1 DJControl Inpulse T7 B0 05 29
19:35:32.336 CC (#37) 12 1 DJControl Inpulse T7 B0 25 0C
19:35:32.360 CC (#5) 41 1 DJControl Inpulse T7 B0 05 29
19:35:32.363 CC (#37) 30 1 DJControl Inpulse T7 B0 25 1E
19:35:32.367 CC (#5) 41 1 DJControl Inpulse T7 B0 05 29
19:35:32.370 CC (#37) 69 1 DJControl Inpulse T7 B0 25 45
19:35:32.426 CC (#5) 41 1 DJControl Inpulse T7 B0 05 29
19:35:32.429 CC (#37) 126 1 DJControl Inpulse T7 B0 25 7E
19:35:32.432 CC (#5) 42 1 DJControl Inpulse T7 B0 05 2A
19:35:32.434 CC (#37) 16 1 DJControl Inpulse T7 B0 25 10
19:35:32.511 CC (#5) 42 1 DJControl Inpulse T7 B0 05 2A
19:35:32.514 CC (#37) 33 1 DJControl Inpulse T7 B0 25 21
19:35:32.531 CC (#5) 42 1 DJControl Inpulse T7 B0 05 2A
19:35:32.537 CC (#37) 81 1 DJControl Inpulse T7 B0 25 51
19:35:32.591 CC (#5) 42 1 DJControl Inpulse T7 B0 05 2A
19:35:32.594 CC (#37) 112 1 DJControl Inpulse T7 B0 25 70
19:35:32.597 CC (#5) 43 1 DJControl Inpulse T7 B0 05 2B
19:35:32.599 CC (#37) 23 1 DJControl Inpulse T7 B0 25 17
19:35:32.689 CC (#5) 43 1 DJControl Inpulse T7 B0 05 2B
19:35:32.692 CC (#37) 41 1 DJControl Inpulse T7 B0 25 29
19:35:32.709 CC (#5) 43 1 DJControl Inpulse T7 B0 05 2B
19:35:32.712 CC (#37) 93 1 DJControl Inpulse T7 B0 25 5D
19:35:32.768 CC (#5) 44 1 DJControl Inpulse T7 B0 05 2C
19:35:32.777 CC (#37) 13 1 DJControl Inpulse T7 B0 25 0D
19:35:32.781 CC (#5) 44 1 DJControl Inpulse T7 B0 05 2C
19:35:32.788 CC (#37) 40 1 DJControl Inpulse T7 B0 25 28
19:35:32.861 CC (#5) 44 1 DJControl Inpulse T7 B0 05 2C
19:35:32.864 CC (#37) 75 1 DJControl Inpulse T7 B0 25 4B
19:35:32.867 CC (#5) 44 1 DJControl Inpulse T7 B0 05 2C
19:35:32.869 CC (#37) 110 1 DJControl Inpulse T7 B0 25 6E
19:35:32.946 CC (#5) 45 1 DJControl Inpulse T7 B0 05 2D
19:35:32.949 CC (#37) 34 1 DJControl Inpulse T7 B0 25 22
19:35:32.960 CC (#5) 45 1 DJControl Inpulse T7 B0 05 2D
19:35:32.963 CC (#37) 56 1 DJControl Inpulse T7 B0 25 38
19:35:33.005 CC (#5) 45 1 DJControl Inpulse T7 B0 05 2D
19:35:33.010 CC (#37) 82 1 DJControl Inpulse T7 B0 25 52
19:35:33.013 CC (#5) 45 1 DJControl Inpulse T7 B0 05 2D
19:35:33.016 CC (#37) 122 1 DJControl Inpulse T7 B0 25 7A
19:35:33.196 CC (#5) 46 1 DJControl Inpulse T7 B0 05 2E
19:35:33.199 CC (#37) 11 1 DJControl Inpulse T7 B0 25 0B
19:35:33.276 CC (#5) 46 1 DJControl Inpulse T7 B0 05 2E
19:35:33.280 CC (#37) 42 1 DJControl Inpulse T7 B0 25 2A
19:35:33.295 CC (#5) 46 1 DJControl Inpulse T7 B0 05 2E
19:35:33.299 CC (#37) 59 1 DJControl Inpulse T7 B0 25 3B
19:35:33.387 CC (#5) 46 1 DJControl Inpulse T7 B0 05 2E
19:35:33.396 CC (#37) 77 1 DJControl Inpulse T7 B0 25 4D
19:35:33.452 CC (#5) 46 1 DJControl Inpulse T7 B0 05 2E
19:35:33.461 CC (#37) 103 1 DJControl Inpulse T7 B0 25 67
19:35:33.465 CC (#5) 47 1 DJControl Inpulse T7 B0 05 2F
19:35:33.478 CC (#37) 6 1 DJControl Inpulse T7 B0 25 06
19:35:33.571 CC (#5) 47 1 DJControl Inpulse T7 B0 05 2F
19:35:33.576 CC (#37) 32 1 DJControl Inpulse T7 B0 25 20
19:35:33.579 CC (#5) 47 1 DJControl Inpulse T7 B0 05 2F
19:35:33.582 CC (#37) 76 1 DJControl Inpulse T7 B0 25 4C
19:35:33.637 CC (#5) 47 1 DJControl Inpulse T7 B0 05 2F
19:35:33.646 CC (#37) 106 1 DJControl Inpulse T7 B0 25 6A
19:35:33.649 CC (#5) 47 1 DJControl Inpulse T7 B0 05 2F
19:35:33.652 CC (#37) 124 1 DJControl Inpulse T7 B0 25 7C
19:35:33.660 CC (#5) 48 1 DJControl Inpulse T7 B0 05 30
19:35:33.663 CC (#37) 13 1 DJControl Inpulse T7 B0 25 0D
19:35:33.709 CC (#5) 48 1 DJControl Inpulse T7 B0 05 30
19:35:33.712 CC (#37) 31 1 DJControl Inpulse T7 B0 25 1F
19:35:33.729 CC (#5) 48 1 DJControl Inpulse T7 B0 05 30
19:35:33.733 CC (#37) 53 1 DJControl Inpulse T7 B0 25 35
19:35:33.744 CC (#5) 48 1 DJControl Inpulse T7 B0 05 30
19:35:33.747 CC (#37) 88 1 DJControl Inpulse T7 B0 25 58
19:35:33.827 CC (#5) 48 1 DJControl Inpulse T7 B0 05 30
19:35:33.831 CC (#37) 105 1 DJControl Inpulse T7 B0 25 69
19:35:33.860 CC (#5) 49 1 DJControl Inpulse T7 B0 05 31
19:35:33.864 CC (#37) 21 1 DJControl Inpulse T7 B0 25 15
19:35:33.900 CC (#5) 49 1 DJControl Inpulse T7 B0 05 31
19:35:33.903 CC (#37) 38 1 DJControl Inpulse T7 B0 25 26
19:35:33.913 CC (#5) 49 1 DJControl Inpulse T7 B0 05 31
19:35:33.917 CC (#37) 56 1 DJControl Inpulse T7 B0 25 38
19:35:33.929 CC (#5) 49 1 DJControl Inpulse T7 B0 05 31
19:35:33.933 CC (#37) 95 1 DJControl Inpulse T7 B0 25 5F
19:35:33.960 CC (#5) 49 1 DJControl Inpulse T7 B0 05 31
19:35:33.966 CC (#37) 113 1 DJControl Inpulse T7 B0 25 71
19:35:33.976 CC (#5) 50 1 DJControl Inpulse T7 B0 05 32
19:35:33.980 CC (#37) 24 1 DJControl Inpulse T7 B0 25 18
19:35:33.986 CC (#5) 50 1 DJControl Inpulse T7 B0 05 32
19:35:33.991 CC (#37) 42 1 DJControl Inpulse T7 B0 25 2A
19:35:34.097 CC (#5) 50 1 DJControl Inpulse T7 B0 05 32
19:35:34.100 CC (#37) 59 1 DJControl Inpulse T7 B0 25 3B
19:35:34.111 CC (#5) 50 1 DJControl Inpulse T7 B0 05 32
19:35:34.119 CC (#37) 103 1 DJControl Inpulse T7 B0 25 67
19:35:34.189 CC (#5) 50 1 DJControl Inpulse T7 B0 05 32
19:35:34.193 CC (#37) 125 1 DJControl Inpulse T7 B0 25 7D
19:35:34.203 CC (#5) 51 1 DJControl Inpulse T7 B0 05 33
19:35:34.211 CC (#37) 49 1 DJControl Inpulse T7 B0 25 31
19:35:34.255 CC (#5) 51 1 DJControl Inpulse T7 B0 05 33
19:35:34.259 CC (#37) 67 1 DJControl Inpulse T7 B0 25 43
19:35:34.262 CC (#5) 51 1 DJControl Inpulse T7 B0 05 33
19:35:34.265 CC (#37) 124 1 DJControl Inpulse T7 B0 25 7C
19:35:34.308 CC (#5) 52 1 DJControl Inpulse T7 B0 05 34
19:35:34.313 CC (#37) 13 1 DJControl Inpulse T7 B0 25 0D
19:35:34.318 CC (#5) 52 1 DJControl Inpulse T7 B0 05 34
19:35:34.327 CC (#37) 61 1 DJControl Inpulse T7 B0 25 3D
19:35:34.354 CC (#5) 52 1 DJControl Inpulse T7 B0 05 34
19:35:34.364 CC (#37) 79 1 DJControl Inpulse T7 B0 25 4F
19:35:34.380 CC (#5) 53 1 DJControl Inpulse T7 B0 05 35
19:35:34.385 CC (#37) 3 1 DJControl Inpulse T7 B0 25 03
19:35:34.420 CC (#5) 53 1 DJControl Inpulse T7 B0 05 35
19:35:34.434 CC (#37) 21 1 DJControl Inpulse T7 B0 25 15
19:35:34.452 CC (#5) 53 1 DJControl Inpulse T7 B0 05 35
19:35:34.458 CC (#37) 78 1 DJControl Inpulse T7 B0 25 4E
19:35:34.518 CC (#5) 53 1 DJControl Inpulse T7 B0 05 35
19:35:34.527 CC (#37) 100 1 DJControl Inpulse T7 B0 25 64
19:35:34.533 CC (#5) 54 1 DJControl Inpulse T7 B0 05 36
19:35:34.538 CC (#37) 20 1 DJControl Inpulse T7 B0 25 14
19:35:34.565 CC (#5) 54 1 DJControl Inpulse T7 B0 05 36
19:35:34.569 CC (#37) 37 1 DJControl Inpulse T7 B0 25 25
19:35:34.578 CC (#5) 54 1 DJControl Inpulse T7 B0 05 36
19:35:34.582 CC (#37) 90 1 DJControl Inpulse T7 B0 25 5A
19:35:34.604 CC (#5) 55 1 DJControl Inpulse T7 B0 05 37
19:35:34.616 CC (#37) 10 1 DJControl Inpulse T7 B0 25 0A
19:35:34.619 CC (#5) 55 1 DJControl Inpulse T7 B0 05 37
19:35:34.625 CC (#37) 32 1 DJControl Inpulse T7 B0 25 20
19:35:34.670 CC (#5) 55 1 DJControl Inpulse T7 B0 05 37
19:35:34.679 CC (#37) 80 1 DJControl Inpulse T7 B0 25 50
19:35:34.685 CC (#5) 55 1 DJControl Inpulse T7 B0 05 37
19:35:34.691 CC (#37) 102 1 DJControl Inpulse T7 B0 25 66
19:35:34.742 CC (#5) 56 1 DJControl Inpulse T7 B0 05 38
19:35:34.746 CC (#37) 39 1 DJControl Inpulse T7 B0 25 27
19:35:34.782 CC (#5) 56 1 DJControl Inpulse T7 B0 05 38
19:35:34.785 CC (#37) 57 1 DJControl Inpulse T7 B0 25 39
19:35:34.795 CC (#5) 56 1 DJControl Inpulse T7 B0 05 38
19:35:34.803 CC (#37) 114 1 DJControl Inpulse T7 B0 25 72
19:35:34.835 CC (#5) 57 1 DJControl Inpulse T7 B0 05 39
19:35:34.847 CC (#37) 47 1 DJControl Inpulse T7 B0 25 2F
19:35:34.874 CC (#5) 57 1 DJControl Inpulse T7 B0 05 39
19:35:34.884 CC (#37) 69 1 DJControl Inpulse T7 B0 25 45
19:35:34.897 CC (#5) 57 1 DJControl Inpulse T7 B0 05 39
19:35:34.914 CC (#37) 126 1 DJControl Inpulse T7 B0 25 7E
19:35:35.019 CC (#5) 58 1 DJControl Inpulse T7 B0 05 3A
19:35:35.029 CC (#37) 50 1 DJControl Inpulse T7 B0 25 32
19:35:35.034 CC (#5) 58 1 DJControl Inpulse T7 B0 05 3A
19:35:35.043 CC (#37) 68 1 DJControl Inpulse T7 B0 25 44
19:35:35.078 CC (#5) 58 1 DJControl Inpulse T7 B0 05 3A
19:35:35.084 CC (#37) 125 1 DJControl Inpulse T7 B0 25 7D
19:35:35.098 CC (#5) 59 1 DJControl Inpulse T7 B0 05 3B
19:35:35.101 CC (#37) 23 1 DJControl Inpulse T7 B0 25 17
19:35:35.118 CC (#5) 59 1 DJControl Inpulse T7 B0 05 3B
19:35:35.132 CC (#37) 80 1 DJControl Inpulse T7 B0 25 50
19:35:35.147 CC (#5) 59 1 DJControl Inpulse T7 B0 05 3B
19:35:35.151 CC (#37) 97 1 DJControl Inpulse T7 B0 25 61
19:35:35.154 CC (#5) 60 1 DJControl Inpulse T7 B0 05 3C
19:35:35.160 CC (#37) 22 1 DJControl Inpulse T7 B0 25 16
19:35:35.190 CC (#5) 60 1 DJControl Inpulse T7 B0 05 3C
19:35:35.194 CC (#37) 65 1 DJControl Inpulse T7 B0 25 41
19:35:35.197 CC (#5) 60 1 DJControl Inpulse T7 B0 05 3C
19:35:35.203 CC (#37) 92 1 DJControl Inpulse T7 B0 25 5C
19:35:35.295 CC (#5) 61 1 DJControl Inpulse T7 B0 05 3D
19:35:35.303 CC (#37) 29 1 DJControl Inpulse T7 B0 25 1D
19:35:35.348 CC (#5) 61 1 DJControl Inpulse T7 B0 05 3D
19:35:35.352 CC (#37) 47 1 DJControl Inpulse T7 B0 25 2F
19:35:35.363 CC (#5) 61 1 DJControl Inpulse T7 B0 05 3D
19:35:35.367 CC (#37) 104 1 DJControl Inpulse T7 B0 25 68
19:35:35.388 CC (#5) 62 1 DJControl Inpulse T7 B0 05 3E
19:35:35.400 CC (#37) 41 1 DJControl Inpulse T7 B0 25 29
19:35:35.415 CC (#5) 62 1 DJControl Inpulse T7 B0 05 3E
19:35:35.424 CC (#37) 116 1 DJControl Inpulse T7 B0 25 74
19:35:35.440 CC (#5) 63 1 DJControl Inpulse T7 B0 05 3F
19:35:35.446 CC (#37) 62 1 DJControl Inpulse T7 B0 25 3E
19:35:35.461 CC (#5) 64 1 DJControl Inpulse T7 B0 05 40
19:35:35.465 CC (#37) 0 1 DJControl Inpulse T7 B0 25 00
19:35:36.576 CC (#5) 64 1 DJControl Inpulse T7 B0 05 40
19:35:36.581 CC (#37) 48 1 DJControl Inpulse T7 B0 25 30
19:35:36.587 CC (#5) 64 1 DJControl Inpulse T7 B0 05 40
19:35:36.595 CC (#37) 71 1 DJControl Inpulse T7 B0 25 47
19:35:36.642 CC (#5) 64 1 DJControl Inpulse T7 B0 05 40
19:35:36.648 CC (#37) 93 1 DJControl Inpulse T7 B0 25 5D
19:35:36.653 CC (#5) 65 1 DJControl Inpulse T7 B0 05 41
19:35:36.660 CC (#37) 14 1 DJControl Inpulse T7 B0 25 0E
19:35:36.734 CC (#5) 65 1 DJControl Inpulse T7 B0 05 41
19:35:36.744 CC (#37) 58 1 DJControl Inpulse T7 B0 25 3A
19:35:36.750 CC (#5) 65 1 DJControl Inpulse T7 B0 05 41
19:35:36.759 CC (#37) 85 1 DJControl Inpulse T7 B0 25 55
19:35:36.800 CC (#5) 65 1 DJControl Inpulse T7 B0 05 41
19:35:36.804 CC (#37) 111 1 DJControl Inpulse T7 B0 25 6F
19:35:36.812 CC (#5) 66 1 DJControl Inpulse T7 B0 05 42
19:35:36.816 CC (#37) 28 1 DJControl Inpulse T7 B0 25 1C
19:35:36.853 CC (#5) 66 1 DJControl Inpulse T7 B0 05 42
19:35:36.863 CC (#37) 50 1 DJControl Inpulse T7 B0 25 32
19:35:36.867 CC (#5) 66 1 DJControl Inpulse T7 B0 05 42
19:35:36.874 CC (#37) 99 1 DJControl Inpulse T7 B0 25 63
19:35:36.899 CC (#5) 66 1 DJControl Inpulse T7 B0 05 42
19:35:36.903 CC (#37) 121 1 DJControl Inpulse T7 B0 25 79
19:35:36.915 CC (#5) 67 1 DJControl Inpulse T7 B0 05 43
19:35:36.920 CC (#37) 37 1 DJControl Inpulse T7 B0 25 25
19:35:36.965 CC (#5) 67 1 DJControl Inpulse T7 B0 05 43
19:35:36.969 CC (#37) 55 1 DJControl Inpulse T7 B0 25 37
19:35:36.980 CC (#5) 67 1 DJControl Inpulse T7 B0 05 43
19:35:36.984 CC (#37) 77 1 DJControl Inpulse T7 B0 25 4D
19:35:37.000 CC (#5) 67 1 DJControl Inpulse T7 B0 05 43
19:35:37.005 CC (#37) 113 1 DJControl Inpulse T7 B0 25 71
19:35:37.064 CC (#5) 68 1 DJControl Inpulse T7 B0 05 44
19:35:37.068 CC (#37) 2 1 DJControl Inpulse T7 B0 25 02
19:35:37.078 CC (#5) 68 1 DJControl Inpulse T7 B0 05 44
19:35:37.085 CC (#37) 42 1 DJControl Inpulse T7 B0 25 2A
19:35:37.098 CC (#5) 68 1 DJControl Inpulse T7 B0 05 44
19:35:37.115 CC (#37) 60 1 DJControl Inpulse T7 B0 25 3C
19:35:37.132 CC (#5) 68 1 DJControl Inpulse T7 B0 05 44
19:35:37.147 CC (#37) 127 1 DJControl Inpulse T7 B0 25 7F
19:35:37.182 CC (#5) 69 1 DJControl Inpulse T7 B0 05 45
19:35:37.186 CC (#37) 21 1 DJControl Inpulse T7 B0 25 15
19:35:37.197 CC (#5) 69 1 DJControl Inpulse T7 B0 05 45
19:35:37.201 CC (#37) 52 1 DJControl Inpulse T7 B0 25 34
19:35:37.215 CC (#5) 69 1 DJControl Inpulse T7 B0 05 45
19:35:37.225 CC (#37) 70 1 DJControl Inpulse T7 B0 25 46
19:35:37.256 CC (#5) 69 1 DJControl Inpulse T7 B0 05 45
19:35:37.261 CC (#37) 92 1 DJControl Inpulse T7 B0 25 5C
19:35:37.264 CC (#5) 69 1 DJControl Inpulse T7 B0 05 45
19:35:37.268 CC (#37) 118 1 DJControl Inpulse T7 B0 25 76
19:35:37.272 CC (#5) 70 1 DJControl Inpulse T7 B0 05 46
19:35:37.276 CC (#37) 8 1 DJControl Inpulse T7 B0 25 08
19:35:37.360 CC (#5) 70 1 DJControl Inpulse T7 B0 05 46
19:35:37.364 CC (#37) 26 1 DJControl Inpulse T7 B0 25 1A
19:35:37.387 CC (#5) 70 1 DJControl Inpulse T7 B0 05 46
19:35:37.400 CC (#37) 57 1 DJControl Inpulse T7 B0 25 39
19:35:37.406 CC (#5) 70 1 DJControl Inpulse T7 B0 05 46
19:35:37.416 CC (#37) 84 1 DJControl Inpulse T7 B0 25 54
19:35:37.452 CC (#5) 71 1 DJControl Inpulse T7 B0 05 47
19:35:37.463 CC (#37) 27 1 DJControl Inpulse T7 B0 25 1B
19:35:37.479 CC (#5) 71 1 DJControl Inpulse T7 B0 05 47
19:35:37.483 CC (#37) 98 1 DJControl Inpulse T7 B0 25 62
19:35:37.499 CC (#5) 72 1 DJControl Inpulse T7 B0 05 48
19:35:37.516 CC (#37) 41 1 DJControl Inpulse T7 B0 25 29
19:35:37.535 CC (#5) 72 1 DJControl Inpulse T7 B0 05 48
19:35:37.557 CC (#37) 76 1 DJControl Inpulse T7 B0 25 4C
19:35:37.566 CC (#5) 72 1 DJControl Inpulse T7 B0 05 48
19:35:37.570 CC (#37) 107 1 DJControl Inpulse T7 B0 25 6B
19:35:37.597 CC (#5) 72 1 DJControl Inpulse T7 B0 05 48
19:35:37.601 CC (#37) 125 1 DJControl Inpulse T7 B0 25 7D
19:35:37.624 CC (#5) 73 1 DJControl Inpulse T7 B0 05 49
19:35:37.628 CC (#37) 15 1 DJControl Inpulse T7 B0 25 0F
19:35:37.649 CC (#5) 73 1 DJControl Inpulse T7 B0 05 49
19:35:37.653 CC (#37) 41 1 DJControl Inpulse T7 B0 25 29
19:35:37.670 CC (#5) 73 1 DJControl Inpulse T7 B0 05 49
19:35:37.685 CC (#37) 59 1 DJControl Inpulse T7 B0 25 3B
19:35:37.699 CC (#5) 73 1 DJControl Inpulse T7 B0 05 49
19:35:37.704 CC (#37) 126 1 DJControl Inpulse T7 B0 25 7E
19:35:37.719 CC (#5) 74 1 DJControl Inpulse T7 B0 05 4A
19:35:37.730 CC (#37) 15 1 DJControl Inpulse T7 B0 25 0F
19:35:37.743 CC (#5) 74 1 DJControl Inpulse T7 B0 05 4A
19:35:37.749 CC (#37) 69 1 DJControl Inpulse T7 B0 25 45
19:35:37.765 CC (#5) 74 1 DJControl Inpulse T7 B0 05 4A
19:35:37.779 CC (#37) 95 1 DJControl Inpulse T7 B0 25 5F
19:35:37.787 CC (#5) 75 1 DJControl Inpulse T7 B0 05 4B
19:35:37.793 CC (#37) 12 1 DJControl Inpulse T7 B0 25 0C
19:35:37.803 CC (#5) 75 1 DJControl Inpulse T7 B0 05 4B
19:35:37.810 CC (#37) 87 1 DJControl Inpulse T7 B0 25 57
19:35:37.819 CC (#5) 76 1 DJControl Inpulse T7 B0 05 4C
19:35:37.831 CC (#37) 26 1 DJControl Inpulse T7 B0 25 1A
19:35:37.846 CC (#5) 76 1 DJControl Inpulse T7 B0 05 4C
19:35:37.852 CC (#37) 92 1 DJControl Inpulse T7 B0 25 5C
19:35:37.869 CC (#5) 76 1 DJControl Inpulse T7 B0 05 4C
19:35:37.878 CC (#37) 110 1 DJControl Inpulse T7 B0 25 6E
19:35:37.892 CC (#5) 77 1 DJControl Inpulse T7 B0 05 4D
19:35:37.899 CC (#37) 40 1 DJControl Inpulse T7 B0 25 28
19:35:37.953 CC (#5) 77 1 DJControl Inpulse T7 B0 05 4D
19:35:37.964 CC (#37) 57 1 DJControl Inpulse T7 B0 25 39
19:35:37.970 CC (#5) 77 1 DJControl Inpulse T7 B0 05 4D
19:35:37.979 CC (#37) 111 1 DJControl Inpulse T7 B0 25 6F
19:35:38.012 CC (#5) 78 1 DJControl Inpulse T7 B0 05 4E
19:35:38.017 CC (#37) 54 1 DJControl Inpulse T7 B0 25 36
19:35:38.039 CC (#5) 78 1 DJControl Inpulse T7 B0 05 4E
19:35:38.045 CC (#37) 93 1 DJControl Inpulse T7 B0 25 5D
19:35:38.050 CC (#5) 79 1 DJControl Inpulse T7 B0 05 4F
19:35:38.055 CC (#37) 1 1 DJControl Inpulse T7 B0 25 01
19:35:38.078 CC (#5) 79 1 DJControl Inpulse T7 B0 05 4F
19:35:38.083 CC (#37) 45 1 DJControl Inpulse T7 B0 25 2D
19:35:38.100 CC (#5) 79 1 DJControl Inpulse T7 B0 05 4F
19:35:38.109 CC (#37) 72 1 DJControl Inpulse T7 B0 25 48
19:35:38.120 CC (#5) 80 1 DJControl Inpulse T7 B0 05 50
19:35:38.131 CC (#37) 19 1 DJControl Inpulse T7 B0 25 13
19:35:38.171 CC (#5) 80 1 DJControl Inpulse T7 B0 05 50
19:35:38.182 CC (#37) 77 1 DJControl Inpulse T7 B0 25 4D
19:35:38.204 CC (#5) 80 1 DJControl Inpulse T7 B0 05 50
19:35:38.229 CC (#37) 95 1 DJControl Inpulse T7 B0 25 5F
19:35:38.246 CC (#5) 81 1 DJControl Inpulse T7 B0 05 51
19:35:38.254 CC (#37) 7 1 DJControl Inpulse T7 B0 25 07
19:35:38.264 CC (#5) 81 1 DJControl Inpulse T7 B0 05 51
19:35:38.269 CC (#37) 29 1 DJControl Inpulse T7 B0 25 1D
19:35:38.284 CC (#5) 81 1 DJControl Inpulse T7 B0 05 51
19:35:38.292 CC (#37) 64 1 DJControl Inpulse T7 B0 25 40
19:35:38.297 CC (#5) 81 1 DJControl Inpulse T7 B0 05 51
19:35:38.301 CC (#37) 96 1 DJControl Inpulse T7 B0 25 60
19:35:38.319 CC (#5) 82 1 DJControl Inpulse T7 B0 05 52
19:35:38.328 CC (#37) 34 1 DJControl Inpulse T7 B0 25 22
19:35:38.346 CC (#5) 82 1 DJControl Inpulse T7 B0 05 52
19:35:38.352 CC (#37) 52 1 DJControl Inpulse T7 B0 25 34
19:35:38.367 CC (#5) 82 1 DJControl Inpulse T7 B0 05 52
19:35:38.375 CC (#37) 105 1 DJControl Inpulse T7 B0 25 69
19:35:38.389 CC (#5) 82 1 DJControl Inpulse T7 B0 05 52
19:35:38.400 CC (#37) 123 1 DJControl Inpulse T7 B0 25 7B
19:35:38.418 CC (#5) 83 1 DJControl Inpulse T7 B0 05 53
19:35:38.427 CC (#37) 53 1 DJControl Inpulse T7 B0 25 35
19:35:38.442 CC (#5) 83 1 DJControl Inpulse T7 B0 05 53
19:35:38.449 CC (#37) 75 1 DJControl Inpulse T7 B0 25 4B
19:35:38.453 CC (#5) 83 1 DJControl Inpulse T7 B0 05 53
19:35:38.464 CC (#37) 115 1 DJControl Inpulse T7 B0 25 73
19:35:38.477 CC (#5) 84 1 DJControl Inpulse T7 B0 05 54
19:35:38.490 CC (#37) 4 1 DJControl Inpulse T7 B0 25 04
19:35:38.500 CC (#5) 84 1 DJControl Inpulse T7 B0 05 54
19:35:38.508 CC (#37) 31 1 DJControl Inpulse T7 B0 25 1F
19:35:38.513 CC (#5) 84 1 DJControl Inpulse T7 B0 05 54
19:35:38.519 CC (#37) 67 1 DJControl Inpulse T7 B0 25 43
19:35:38.532 CC (#5) 85 1 DJControl Inpulse T7 B0 05 55
19:35:38.538 CC (#37) 14 1 DJControl Inpulse T7 B0 25 0E
19:35:38.549 CC (#5) 85 1 DJControl Inpulse T7 B0 05 55
19:35:38.554 CC (#37) 49 1 DJControl Inpulse T7 B0 25 31
19:35:38.560 CC (#5) 85 1 DJControl Inpulse T7 B0 05 55
19:35:38.565 CC (#37) 81 1 DJControl Inpulse T7 B0 25 51
19:35:38.575 CC (#5) 86 1 DJControl Inpulse T7 B0 05 56
19:35:38.580 CC (#37) 6 1 DJControl Inpulse T7 B0 25 06
19:35:38.585 CC (#5) 86 1 DJControl Inpulse T7 B0 05 56
19:35:38.596 CC (#37) 28 1 DJControl Inpulse T7 B0 25 1C
19:35:38.611 CC (#5) 86 1 DJControl Inpulse T7 B0 05 56
19:35:38.620 CC (#37) 72 1 DJControl Inpulse T7 B0 25 48
19:35:38.633 CC (#5) 86 1 DJControl Inpulse T7 B0 05 56
19:35:38.641 CC (#37) 99 1 DJControl Inpulse T7 B0 25 63
19:35:38.654 CC (#5) 87 1 DJControl Inpulse T7 B0 05 57
19:35:38.661 CC (#37) 15 1 DJControl Inpulse T7 B0 25 0F
19:35:38.666 CC (#5) 87 1 DJControl Inpulse T7 B0 05 57
19:35:38.671 CC (#37) 42 1 DJControl Inpulse T7 B0 25 2A
19:35:38.698 CC (#5) 87 1 DJControl Inpulse T7 B0 05 57
19:35:38.704 CC (#37) 69 1 DJControl Inpulse T7 B0 25 45
19:35:38.714 CC (#5) 87 1 DJControl Inpulse T7 B0 05 57
19:35:38.719 CC (#37) 104 1 DJControl Inpulse T7 B0 25 68
19:35:38.732 CC (#5) 87 1 DJControl Inpulse T7 B0 05 57
19:35:38.738 CC (#37) 122 1 DJControl Inpulse T7 B0 25 7A
19:35:38.747 CC (#5) 88 1 DJControl Inpulse T7 B0 05 58
19:35:38.752 CC (#37) 12 1 DJControl Inpulse T7 B0 25 0C
19:35:38.766 CC (#5) 88 1 DJControl Inpulse T7 B0 05 58
19:35:38.774 CC (#37) 34 1 DJControl Inpulse T7 B0 25 22
19:35:38.782 CC (#5) 88 1 DJControl Inpulse T7 B0 05 58
19:35:38.794 CC (#37) 52 1 DJControl Inpulse T7 B0 25 34
19:35:38.811 CC (#5) 88 1 DJControl Inpulse T7 B0 05 58
19:35:38.819 CC (#37) 118 1 DJControl Inpulse T7 B0 25 76
19:35:38.826 CC (#5) 89 1 DJControl Inpulse T7 B0 05 59
19:35:38.834 CC (#37) 8 1 DJControl Inpulse T7 B0 25 08
19:35:38.846 CC (#5) 89 1 DJControl Inpulse T7 B0 05 59
19:35:38.852 CC (#37) 66 1 DJControl Inpulse T7 B0 25 42
19:35:38.865 CC (#5) 89 1 DJControl Inpulse T7 B0 05 59
19:35:38.873 CC (#37) 83 1 DJControl Inpulse T7 B0 25 53
19:35:38.882 CC (#5) 89 1 DJControl Inpulse T7 B0 05 59
19:35:38.889 CC (#37) 114 1 DJControl Inpulse T7 B0 25 72
19:35:38.903 CC (#5) 90 1 DJControl Inpulse T7 B0 05 5A
19:35:38.913 CC (#37) 9 1 DJControl Inpulse T7 B0 25 09
19:35:38.930 CC (#5) 90 1 DJControl Inpulse T7 B0 05 5A
19:35:38.936 CC (#37) 84 1 DJControl Inpulse T7 B0 25 54
19:35:38.945 CC (#5) 90 1 DJControl Inpulse T7 B0 05 5A
19:35:38.950 CC (#37) 102 1 DJControl Inpulse T7 B0 25 66
19:35:38.958 CC (#5) 90 1 DJControl Inpulse T7 B0 05 5A
19:35:38.963 CC (#37) 119 1 DJControl Inpulse T7 B0 25 77
19:35:38.968 CC (#5) 91 1 DJControl Inpulse T7 B0 05 5B
19:35:38.975 CC (#37) 23 1 DJControl Inpulse T7 B0 25 17
19:35:38.986 CC (#5) 91 1 DJControl Inpulse T7 B0 05 5B
19:35:38.996 CC (#37) 40 1 DJControl Inpulse T7 B0 25 28
19:35:39.002 CC (#5) 91 1 DJControl Inpulse T7 B0 05 5B
19:35:39.012 CC (#37) 76 1 DJControl Inpulse T7 B0 25 4C
19:35:39.017 CC (#5) 91 1 DJControl Inpulse T7 B0 05 5B
19:35:39.023 CC (#37) 94 1 DJControl Inpulse T7 B0 25 5E
19:35:39.034 CC (#5) 91 1 DJControl Inpulse T7 B0 05 5B
19:35:39.043 CC (#37) 111 1 DJControl Inpulse T7 B0 25 6F
19:35:39.049 CC (#5) 92 1 DJControl Inpulse T7 B0 05 5C
19:35:39.056 CC (#37) 41 1 DJControl Inpulse T7 B0 25 29
19:35:39.074 CC (#5) 92 1 DJControl Inpulse T7 B0 05 5C
19:35:39.081 CC (#37) 99 1 DJControl Inpulse T7 B0 25 63
19:35:39.093 CC (#5) 92 1 DJControl Inpulse T7 B0 05 5C
19:35:39.102 CC (#37) 116 1 DJControl Inpulse T7 B0 25 74
19:35:39.125 CC (#5) 93 1 DJControl Inpulse T7 B0 05 5D
19:35:39.134 CC (#37) 42 1 DJControl Inpulse T7 B0 25 2A
19:35:39.147 CC (#5) 93 1 DJControl Inpulse T7 B0 05 5D
19:35:39.155 CC (#37) 64 1 DJControl Inpulse T7 B0 25 40
19:35:39.164 CC (#5) 93 1 DJControl Inpulse T7 B0 05 5D
19:35:39.171 CC (#37) 122 1 DJControl Inpulse T7 B0 25 7A
19:35:39.185 CC (#5) 94 1 DJControl Inpulse T7 B0 05 5E
19:35:39.193 CC (#37) 20 1 DJControl Inpulse T7 B0 25 14
19:35:39.199 CC (#5) 94 1 DJControl Inpulse T7 B0 05 5E
19:35:39.204 CC (#37) 56 1 DJControl Inpulse T7 B0 25 38
19:35:39.220 CC (#5) 94 1 DJControl Inpulse T7 B0 05 5E
19:35:39.228 CC (#37) 73 1 DJControl Inpulse T7 B0 25 49
19:35:39.233 CC (#5) 94 1 DJControl Inpulse T7 B0 05 5E
19:35:39.241 CC (#37) 113 1 DJControl Inpulse T7 B0 25 71
19:35:39.266 CC (#5) 95 1 DJControl Inpulse T7 B0 05 5F
19:35:39.273 CC (#37) 12 1 DJControl Inpulse T7 B0 25 0C
19:35:39.292 CC (#5) 95 1 DJControl Inpulse T7 B0 05 5F
19:35:39.300 CC (#37) 47 1 DJControl Inpulse T7 B0 25 2F
19:35:39.312 CC (#5) 95 1 DJControl Inpulse T7 B0 05 5F
19:35:39.318 CC (#37) 83 1 DJControl Inpulse T7 B0 25 53
19:35:39.331 CC (#5) 96 1 DJControl Inpulse T7 B0 05 60
19:35:39.339 CC (#37) 30 1 DJControl Inpulse T7 B0 25 1E
19:35:39.350 CC (#5) 96 1 DJControl Inpulse T7 B0 05 60
19:35:39.357 CC (#37) 84 1 DJControl Inpulse T7 B0 25 54
19:35:39.370 CC (#5) 96 1 DJControl Inpulse T7 B0 05 60
19:35:39.387 CC (#37) 101 1 DJControl Inpulse T7 B0 25 65
19:35:39.401 CC (#5) 97 1 DJControl Inpulse T7 B0 05 61
19:35:39.411 CC (#37) 36 1 DJControl Inpulse T7 B0 25 24
19:35:39.428 CC (#5) 97 1 DJControl Inpulse T7 B0 05 61
19:35:39.436 CC (#37) 53 1 DJControl Inpulse T7 B0 25 35
19:35:39.447 CC (#5) 97 1 DJControl Inpulse T7 B0 05 61
19:35:39.453 CC (#37) 107 1 DJControl Inpulse T7 B0 25 6B
19:35:39.462 CC (#5) 98 1 DJControl Inpulse T7 B0 05 62
19:35:39.467 CC (#37) 54 1 DJControl Inpulse T7 B0 25 36
19:35:39.482 CC (#5) 98 1 DJControl Inpulse T7 B0 05 62
19:35:39.488 CC (#37) 121 1 DJControl Inpulse T7 B0 25 79
19:35:39.497 CC (#5) 99 1 DJControl Inpulse T7 B0 05 63
19:35:39.502 CC (#37) 19 1 DJControl Inpulse T7 B0 25 13
19:35:39.510 CC (#5) 99 1 DJControl Inpulse T7 B0 05 63
19:35:39.515 CC (#37) 64 1 DJControl Inpulse T7 B0 25 40
19:35:39.520 CC (#5) 99 1 DJControl Inpulse T7 B0 05 63
19:35:39.527 CC (#37) 103 1 DJControl Inpulse T7 B0 25 67
19:35:39.532 CC (#5) 100 1 DJControl Inpulse T7 B0 05 64
19:35:39.538 CC (#37) 15 1 DJControl Inpulse T7 B0 25 0F
19:35:39.545 CC (#5) 100 1 DJControl Inpulse T7 B0 05 64
19:35:39.550 CC (#37) 91 1 DJControl Inpulse T7 B0 25 5B
19:35:39.563 CC (#5) 101 1 DJControl Inpulse T7 B0 05 65
19:35:39.569 CC (#37) 25 1 DJControl Inpulse T7 B0 25 19
19:35:39.582 CC (#5) 101 1 DJControl Inpulse T7 B0 05 65
19:35:39.589 CC (#37) 96 1 DJControl Inpulse T7 B0 25 60
19:35:39.599 CC (#5) 102 1 DJControl Inpulse T7 B0 05 66
19:35:39.604 CC (#37) 39 1 DJControl Inpulse T7 B0 25 27
19:35:39.611 CC (#5) 102 1 DJControl Inpulse T7 B0 05 66
19:35:39.616 CC (#37) 106 1 DJControl Inpulse T7 B0 25 6A
19:35:39.623 CC (#5) 103 1 DJControl Inpulse T7 B0 05 67
19:35:39.629 CC (#37) 0 1 DJControl Inpulse T7 B0 25 00
19:35:39.635 CC (#5) 103 1 DJControl Inpulse T7 B0 05 67
19:35:39.643 CC (#37) 53 1 DJControl Inpulse T7 B0 25 35
19:35:39.653 CC (#5) 103 1 DJControl Inpulse T7 B0 05 67
19:35:39.661 CC (#37) 88 1 DJControl Inpulse T7 B0 25 58
19:35:39.667 CC (#5) 103 1 DJControl Inpulse T7 B0 05 67
19:35:39.673 CC (#37) 124 1 DJControl Inpulse T7 B0 25 7C
19:35:39.683 CC (#5) 104 1 DJControl Inpulse T7 B0 05 68
19:35:39.691 CC (#37) 63 1 DJControl Inpulse T7 B0 25 3F
19:35:39.707 CC (#5) 104 1 DJControl Inpulse T7 B0 05 68
19:35:39.713 CC (#37) 85 1 DJControl Inpulse T7 B0 25 55
19:35:39.719 CC (#5) 105 1 DJControl Inpulse T7 B0 05 69
19:35:39.729 CC (#37) 6 1 DJControl Inpulse T7 B0 25 06
19:35:39.753 CC (#5) 105 1 DJControl Inpulse T7 B0 05 69
19:35:39.765 CC (#37) 28 1 DJControl Inpulse T7 B0 25 1C
19:35:39.779 CC (#5) 105 1 DJControl Inpulse T7 B0 05 69
19:35:39.787 CC (#37) 68 1 DJControl Inpulse T7 B0 25 44
19:35:39.801 CC (#5) 105 1 DJControl Inpulse T7 B0 05 69
19:35:39.809 CC (#37) 85 1 DJControl Inpulse T7 B0 25 55
19:35:39.815 CC (#5) 106 1 DJControl Inpulse T7 B0 05 6A
19:35:39.820 CC (#37) 15 1 DJControl Inpulse T7 B0 25 0F
19:35:39.836 CC (#5) 106 1 DJControl Inpulse T7 B0 05 6A
19:35:39.844 CC (#37) 33 1 DJControl Inpulse T7 B0 25 21
19:35:39.861 CC (#5) 106 1 DJControl Inpulse T7 B0 05 6A
19:35:39.875 CC (#37) 91 1 DJControl Inpulse T7 B0 25 5B
19:35:39.893 CC (#5) 106 1 DJControl Inpulse T7 B0 05 6A
19:35:39.912 CC (#37) 122 1 DJControl Inpulse T7 B0 25 7A
19:35:39.917 CC (#5) 107 1 DJControl Inpulse T7 B0 05 6B
19:35:39.927 CC (#37) 38 1 DJControl Inpulse T7 B0 25 26
19:35:39.942 CC (#5) 107 1 DJControl Inpulse T7 B0 05 6B
19:35:39.948 CC (#37) 109 1 DJControl Inpulse T7 B0 25 6D
19:35:39.954 CC (#5) 108 1 DJControl Inpulse T7 B0 05 6C
19:35:39.965 CC (#37) 12 1 DJControl Inpulse T7 B0 25 0C
19:35:39.980 CC (#5) 108 1 DJControl Inpulse T7 B0 05 6C
19:35:39.986 CC (#37) 52 1 DJControl Inpulse T7 B0 25 34
19:35:39.998 CC (#5) 108 1 DJControl Inpulse T7 B0 05 6C
19:35:40.003 CC (#37) 114 1 DJControl Inpulse T7 B0 25 72
19:35:40.025 CC (#5) 109 1 DJControl Inpulse T7 B0 05 6D
19:35:40.031 CC (#37) 13 1 DJControl Inpulse T7 B0 25 0D
19:35:40.036 CC (#5) 109 1 DJControl Inpulse T7 B0 05 6D
19:35:40.048 CC (#37) 66 1 DJControl Inpulse T7 B0 25 42
19:35:40.055 CC (#5) 109 1 DJControl Inpulse T7 B0 05 6D
19:35:40.063 CC (#37) 84 1 DJControl Inpulse T7 B0 25 54
19:35:40.069 CC (#5) 110 1 DJControl Inpulse T7 B0 05 6E
19:35:40.077 CC (#37) 9 1 DJControl Inpulse T7 B0 25 09
19:35:40.092 CC (#5) 110 1 DJControl Inpulse T7 B0 05 6E
19:35:40.100 CC (#37) 80 1 DJControl Inpulse T7 B0 25 50
19:35:40.118 CC (#5) 111 1 DJControl Inpulse T7 B0 05 6F
19:35:40.127 CC (#37) 19 1 DJControl Inpulse T7 B0 25 13
19:35:40.148 CC (#5) 111 1 DJControl Inpulse T7 B0 05 6F
19:35:40.155 CC (#37) 41 1 DJControl Inpulse T7 B0 25 29
19:35:40.165 CC (#5) 111 1 DJControl Inpulse T7 B0 05 6F
19:35:40.169 CC (#37) 94 1 DJControl Inpulse T7 B0 25 5E
19:35:40.183 CC (#5) 111 1 DJControl Inpulse T7 B0 05 6F
19:35:40.190 CC (#37) 121 1 DJControl Inpulse T7 B0 25 79
19:35:40.200 CC (#5) 112 1 DJControl Inpulse T7 B0 05 70
19:35:40.208 CC (#37) 37 1 DJControl Inpulse T7 B0 25 25
19:35:40.221 CC (#5) 112 1 DJControl Inpulse T7 B0 05 70
19:35:40.229 CC (#37) 59 1 DJControl Inpulse T7 B0 25 3B
19:35:40.234 CC (#5) 112 1 DJControl Inpulse T7 B0 05 70
19:35:40.246 CC (#37) 108 1 DJControl Inpulse T7 B0 25 6C
19:35:40.266 CC (#5) 113 1 DJControl Inpulse T7 B0 05 71
19:35:40.273 CC (#37) 2 1 DJControl Inpulse T7 B0 25 02
19:35:40.282 CC (#5) 113 1 DJControl Inpulse T7 B0 05 71
19:35:40.293 CC (#37) 33 1 DJControl Inpulse T7 B0 25 21
19:35:40.299 CC (#5) 113 1 DJControl Inpulse T7 B0 05 71
19:35:40.307 CC (#37) 51 1 DJControl Inpulse T7 B0 25 33
19:35:40.320 CC (#5) 113 1 DJControl Inpulse T7 B0 05 71
19:35:40.331 CC (#37) 82 1 DJControl Inpulse T7 B0 25 52
19:35:40.346 CC (#5) 113 1 DJControl Inpulse T7 B0 05 71
19:35:40.357 CC (#37) 118 1 DJControl Inpulse T7 B0 25 76
19:35:40.401 CC (#5) 114 1 DJControl Inpulse T7 B0 05 72
19:35:40.424 CC (#37) 21 1 DJControl Inpulse T7 B0 25 15
19:35:40.431 CC (#5) 114 1 DJControl Inpulse T7 B0 05 72
19:35:40.437 CC (#37) 56 1 DJControl Inpulse T7 B0 25 38
19:35:40.456 CC (#5) 114 1 DJControl Inpulse T7 B0 05 72
19:35:40.463 CC (#37) 74 1 DJControl Inpulse T7 B0 25 4A
19:35:40.480 CC (#5) 115 1 DJControl Inpulse T7 B0 05 73
19:35:40.487 CC (#37) 8 1 DJControl Inpulse T7 B0 25 08
19:35:40.507 CC (#5) 115 1 DJControl Inpulse T7 B0 05 73
19:35:40.514 CC (#37) 79 1 DJControl Inpulse T7 B0 25 4F
19:35:40.531 CC (#5) 115 1 DJControl Inpulse T7 B0 05 73
19:35:40.538 CC (#37) 101 1 DJControl Inpulse T7 B0 25 65
19:35:40.558 CC (#5) 116 1 DJControl Inpulse T7 B0 05 74
19:35:40.565 CC (#37) 13 1 DJControl Inpulse T7 B0 25 0D
19:35:40.583 CC (#5) 116 1 DJControl Inpulse T7 B0 05 74
19:35:40.592 CC (#37) 31 1 DJControl Inpulse T7 B0 25 1F
19:35:40.607 CC (#5) 116 1 DJControl Inpulse T7 B0 05 74
19:35:40.622 CC (#37) 93 1 DJControl Inpulse T7 B0 25 5D
19:35:40.659 CC (#5) 116 1 DJControl Inpulse T7 B0 05 74
19:35:40.669 CC (#37) 115 1 DJControl Inpulse T7 B0 25 73
19:35:40.678 CC (#5) 117 1 DJControl Inpulse T7 B0 05 75
19:35:40.684 CC (#37) 40 1 DJControl Inpulse T7 B0 25 28
19:35:40.703 CC (#5) 117 1 DJControl Inpulse T7 B0 05 75
19:35:40.728 CC (#37) 107 1 DJControl Inpulse T7 B0 25 6B
19:35:40.745 CC (#5) 117 1 DJControl Inpulse T7 B0 05 75
19:35:40.752 CC (#37) 125 1 DJControl Inpulse T7 B0 25 7D
19:35:40.770 CC (#5) 118 1 DJControl Inpulse T7 B0 05 76
19:35:40.780 CC (#37) 54 1 DJControl Inpulse T7 B0 25 36
19:35:40.801 CC (#5) 118 1 DJControl Inpulse T7 B0 05 76
19:35:40.811 CC (#37) 81 1 DJControl Inpulse T7 B0 25 51
19:35:40.817 CC (#5) 118 1 DJControl Inpulse T7 B0 05 76
19:35:40.828 CC (#37) 125 1 DJControl Inpulse T7 B0 25 7D
19:35:40.843 CC (#5) 119 1 DJControl Inpulse T7 B0 05 77
19:35:40.850 CC (#37) 60 1 DJControl Inpulse T7 B0 25 3C
19:35:40.869 CC (#5) 119 1 DJControl Inpulse T7 B0 05 77
19:35:40.885 CC (#37) 77 1 DJControl Inpulse T7 B0 25 4D
19:35:40.911 CC (#5) 119 1 DJControl Inpulse T7 B0 05 77
19:35:40.918 CC (#37) 104 1 DJControl Inpulse T7 B0 25 68
19:35:40.930 CC (#5) 119 1 DJControl Inpulse T7 B0 05 77
19:35:40.937 CC (#37) 122 1 DJControl Inpulse T7 B0 25 7A
19:35:40.949 CC (#5) 120 1 DJControl Inpulse T7 B0 05 78
19:35:40.958 CC (#37) 11 1 DJControl Inpulse T7 B0 25 0B
19:35:40.974 CC (#5) 120 1 DJControl Inpulse T7 B0 05 78
19:35:40.983 CC (#37) 47 1 DJControl Inpulse T7 B0 25 2F
19:35:40.995 CC (#5) 120 1 DJControl Inpulse T7 B0 05 78
19:35:41.005 CC (#37) 78 1 DJControl Inpulse T7 B0 25 4E
19:35:41.013 CC (#5) 121 1 DJControl Inpulse T7 B0 05 79
19:35:41.021 CC (#37) 17 1 DJControl Inpulse T7 B0 25 11
19:35:41.036 CC (#5) 121 1 DJControl Inpulse T7 B0 05 79
19:35:41.047 CC (#37) 34 1 DJControl Inpulse T7 B0 25 22
19:35:41.054 CC (#5) 121 1 DJControl Inpulse T7 B0 05 79
19:35:41.065 CC (#37) 92 1 DJControl Inpulse T7 B0 25 5C
19:35:41.071 CC (#5) 121 1 DJControl Inpulse T7 B0 05 79
19:35:41.079 CC (#37) 110 1 DJControl Inpulse T7 B0 25 6E
19:35:41.085 CC (#5) 122 1 DJControl Inpulse T7 B0 05 7A
19:35:41.092 CC (#37) 31 1 DJControl Inpulse T7 B0 25 1F
19:35:41.098 CC (#5) 122 1 DJControl Inpulse T7 B0 05 7A
19:35:41.105 CC (#37) 48 1 DJControl Inpulse T7 B0 25 30
19:35:41.112 CC (#5) 122 1 DJControl Inpulse T7 B0 05 7A
19:35:41.119 CC (#37) 102 1 DJControl Inpulse T7 B0 25 66
19:35:41.144 CC (#5) 122 1 DJControl Inpulse T7 B0 05 7A
19:35:41.151 CC (#37) 119 1 DJControl Inpulse T7 B0 25 77
19:35:41.162 CC (#5) 123 1 DJControl Inpulse T7 B0 05 7B
19:35:41.168 CC (#37) 53 1 DJControl Inpulse T7 B0 25 35
19:35:41.176 CC (#5) 123 1 DJControl Inpulse T7 B0 05 7B
19:35:41.182 CC (#37) 120 1 DJControl Inpulse T7 B0 25 78
19:35:41.188 CC (#5) 124 1 DJControl Inpulse T7 B0 05 7C
19:35:41.196 CC (#37) 32 1 DJControl Inpulse T7 B0 25 20
19:35:41.202 CC (#5) 124 1 DJControl Inpulse T7 B0 05 7C
19:35:41.210 CC (#37) 67 1 DJControl Inpulse T7 B0 25 43
19:35:41.225 CC (#5) 124 1 DJControl Inpulse T7 B0 05 7C
19:35:41.232 CC (#37) 107 1 DJControl Inpulse T7 B0 25 6B
19:35:41.244 CC (#5) 125 1 DJControl Inpulse T7 B0 05 7D
19:35:41.251 CC (#37) 2 1 DJControl Inpulse T7 B0 25 02
19:35:41.259 CC (#5) 125 1 DJControl Inpulse T7 B0 05 7D
19:35:41.265 CC (#37) 55 1 DJControl Inpulse T7 B0 25 37
19:35:41.273 CC (#5) 125 1 DJControl Inpulse T7 B0 05 7D
19:35:41.281 CC (#37) 81 1 DJControl Inpulse T7 B0 25 51
19:35:41.299 CC (#5) 125 1 DJControl Inpulse T7 B0 05 7D
19:35:41.310 CC (#37) 117 1 DJControl Inpulse T7 B0 25 75
19:35:41.317 CC (#5) 126 1 DJControl Inpulse T7 B0 05 7E
19:35:41.342 CC (#37) 20 1 DJControl Inpulse T7 B0 25 14
19:35:41.365 CC (#5) 126 1 DJControl Inpulse T7 B0 05 7E
19:35:41.373 CC (#37) 42 1 DJControl Inpulse T7 B0 25 2A
19:35:41.385 CC (#5) 126 1 DJControl Inpulse T7 B0 05 7E
19:35:41.398 CC (#37) 60 1 DJControl Inpulse T7 B0 25 3C
19:35:41.410 CC (#5) 126 1 DJControl Inpulse T7 B0 05 7E
19:35:41.419 CC (#37) 78 1 DJControl Inpulse T7 B0 25 4E
19:35:41.435 CC (#5) 126 1 DJControl Inpulse T7 B0 05 7E
19:35:41.445 CC (#37) 95 1 DJControl Inpulse T7 B0 25 5F
19:35:41.452 CC (#5) 127 1 DJControl Inpulse T7 B0 05 7F
19:35:41.463 CC (#37) 3 1 DJControl Inpulse T7 B0 25 03
19:35:41.470 CC (#5) 127 1 DJControl Inpulse T7 B0 05 7F
19:35:41.478 CC (#37) 21 1 DJControl Inpulse T7 B0 25 15
19:35:41.499 CC (#5) 127 1 DJControl Inpulse T7 B0 05 7F
19:35:41.512 CC (#37) 38 1 DJControl Inpulse T7 B0 25 26
19:35:41.530 CC (#5) 127 1 DJControl Inpulse T7 B0 05 7F
19:35:41.537 CC (#37) 65 1 DJControl Inpulse T7 B0 25 41
19:35:41.561 CC (#5) 127 1 DJControl Inpulse T7 B0 05 7F
19:35:41.568 CC (#37) 87 1 DJControl Inpulse T7 B0 25 57
19:35:41.588 CC (#5) 127 1 DJControl Inpulse T7 B0 05 7F
19:35:41.597 CC (#37) 105 1 DJControl Inpulse T7 B0 25 69
19:35:41.634 CC (#5) 127 1 DJControl Inpulse T7 B0 05 7F
19:35:41.657 CC (#37) 127 1 DJControl Inpulse T7 B0 25 7F
The headphone output issue remains unchanged.
Kind regards
Hello @MIBZIC,
Thank you for your help. After changing the cookie settings, the reCAPTCHA issue was resolved and I was able to sign in.
Unfortunately, I am now experiencing another problem when creating the support request. The page has been stuck on the loading screen shown in the attached screenshot for approximately one hour, and I am unable to continue or complete the request.
I have already refreshed the page and tried again, but the issue remains.
Is there perhaps an equally simple fix for this problem as well? 😄 Otherwise, could you please advise me how to proceed or open the support request manually?
Kind regards
Hello DJGiggola,
I have not the solution but I have an idea of  your problem (which I have not seen elsewhere for the moment).
DJControl T10 has a pass-throught status in headphones when not controlled, and when you turn a knob/push the master pfl button, the audio in headphones is reinitialized, so it makes sense it is temporarily muted, just what does not work is that the sound remains muted.
Please confirm if
1) when you do not touch Cue to Mix potentiometer or master preview push button, the headphones volume knob works,
2) you connect only 1 headphones output (1/8" or 1/4", not both at the same time) and confirm you get the same muted headphones symptom ob both headphones plugs.
I have not duplicated your issue, but we may try the following process:
  1. right click on Windows > Installed apps > DJHerculesMix product series drivers
  2. uninstall DJHerculesMix product series drivers
  3. reboot the computer
  4. install Hercules DJ drivers 2023.HDJS.2 from https://support.hercules.com/en/product/djcontrolinpulset7-en/
  5. reboot on the PC
  6. test if you still have the muted headphones bug.
Please precise at which step you are blocked once connected to support.hercules.com website:
1) At the dashboard landing page
2) Or at the first page when you click on "New Query"
3) Or later, once you have set your country & language, when you click on Next
when you should select the category of your message
Remark: one cannot upload directly an image in a post in the forum.
The way I post images:
1) I upload images files on hosting websites: I generally use https://postimages.org/
2) I copy the complete page address of the image (address ending in .jpg or .png)
3) I paste the image address in my message (gif, png or jpg, but no webp or avif format)
4) some image hosting websites are banned.
Thank you for the explanation.
I can confirm the following:
  1. The headphone volume knob works normally and I can adjust the headphone volume without any issue.
  2. I can also select and preview both decks individually through the headphones. The headphone output only becomes muted when I either:
    • press the Master Cue/PFL button, or
    • move the Cue/Mix potentiometer, regardless of its current position.
  3. I only use the 1/8-inch headphone output. I do not have headphones with a 1/4-inch plug and do not plan to use that output, so I cannot currently test the second headphone socket. Only one headphone output is connected at a time.
I have already carried out the driver procedure as described:
  • uninstalled the Hercules driver package
  • rebooted the computer
  • removed the T7 audio-device installation from Windows Device Manager, including the associated driver entries
  • installed the 2023.HDJS.2 package
  • rebooted again
  • tested the controller
Unfortunately, the same headphone-muting issue remained. I also repeated the process with the 2025 driver package, with the same result.
Therefore, deck preview and headphone volume work correctly, but reinitialising the headphone mix through Master Cue or Cue/Mix causes the audio to remain permanently muted until the controller is restarted.
I am blocked at the final step, after clicking “Complete”. The page then remains stuck on the loading screen and the request is not submitted.
Screenshot:
Hello DJ Giggola,
Thanks for your explanation.
My hypothesis of muting caused by the first change of headphones status does not match your description of previewing deck 1 or deck 2, so I will look for another direction.
