Repetitive static noise
Hello, i have a problem i think having to do with my DJ controller INPULSE T7. No matter the application i use, wether that be soundcloud, itunes, or serato/djuiced... There is a repetitive static noise every other second when playing music through my bookshelf speakers. If the brand has any matter they are the KRK ROKIT5. I have tried to change my xlr cables and still the is the constant noise, the only other two cables plugged into the board are USB and the power supply cable which i dont think would be the problem. Thanks for the help in advance would love to get this figured out as the Dj controller is fairly new.
Topic Tags
Hello BaileyM,
Welcome to the forum.
1) What is your computer brand & model?
If the computer is a laptop, can you try using it on its battery to check if you still have this static noise?
That is the way to check whether the noise may come from the computer power supply.
2) Have you tried powering the speakers / computer / DJControl Inpulse to the same power outlet (via a power strip) to make sure there is no ground loop?
3) Do you head this noise in both speakers or only in 1 speaker?
4) Have you tried connecting also to the RCA outputs on DJC Inpulse T7?
If yes, what was the result?
5) Is the click dependent on DJC Inpulse T7 master output level?
Do you hear less click when you reduce the master volume on DJC Inpulse T7.
