PROBLEM WITH MI DJ ...
PROBLEM WITH MI DJ CONSOLE MK4 NOT TURN ON
I HAVE A PROBLEM WITH MY DJ Console MK4
THE COMPUTER DOES NOT RECOGNIZE IT OR IT DOES NOT TURN ON OR DO ANYTHING I WOULD LIKE TO TRY RECOVERING THE EPRROM I WOULD APPRECIATE IF SOMEONE CAN GIVE ME THE .BIN AND THE LATEST FIRMWARE TO UPDATE THANK YOU VERY MUCH FOR YOUR TIME
Hello Nacho1981,
Please do not write messages in capital letters:
- capital letters are considered as shouting on forums
- for this reason messages in capital letters generally receive no answer, and may be deleted by maintenance bots.
Have you access to a PC with Windows 7 or 8.0 to test the DJConsole Mk4?
If the firmware is old but not broken, then the DJConsole MK4 can be detected on these computers and if it is properly detected, you may update the firmware on such computer in adding a USB hub powered by a power adapter between the computer and the DJ controller.
If you have no computer with these old operating system, then you cannot reprogram the firmware via the USB and you need to open the controller to remove the eeprom and program it on an eeprom burner.
Excuse me dear, I didn't know about the capitalization issue.
I tried it on a computer with Windows 7 and the console does not recognize me.
I have the eeprom recorder, I would appreciate if you could send me the .bin to do the programming, thank you very much for your time
Hello Nacho1981,
I have sent you the link to the bin file in a private message.
