Crossfader Serato P...
Crossfader Serato Pro with Impulse 500
5 Users
Hello! I am trying to use my impulse 500 with Serato DJ pro and the crossfader is horrible almost unuseable. When trying to mix both songs are extremely quiet when the crossfader is in the center but when you push to the crossfader to one side the volume is noticeably louder making all transitions noticeable almost making the crossfader useless. I know Serato had an update giving this board some ability to adjust in settings however it still is unuseable. Could there be a way to adjust the crossfader similar to how it is in DJuced software with the adjustable graph?
This topic was modified 2 years ago by DJ HKR
Hello DJHKR,
Since Serato DJ Pro 3.1.4 released on June 4th, you can gradually set the crossfader curve for Hercules DJControl Inpulse 500.
https://serato.com/dj/pro/downloads
Boa noite eu estou enfrentando o mesmo problema o crossfader não está funcionando no serato e djuced estou com o mesmo dilema como que calibra por favor me ajude
Me mande o guia de calibração por favor do crossfader
bagi link nya dong
rtp nya dong
André,
This area is a user forum, it is not an area where you chat with anybody in real time: other users may answer you later, after reading your message, if your message includes a detailed technical description (description of the DJ controller environment and f the technical issue, if any).
If your DJ controller is DJControl Inpulse  and your crossfader is disabled in Djuced and Serato, then you should look at the position of the 3-position switch located between the 2 volume faders:
- on left, the crossfader curve is slow (= mix)
- on the middle, the crossfader curve is fast (= scratch)
- on right, the crossfader curve is off (crossfader disabled).
So if the crossfader curve is set on off, move the crossfader curve switch to left if you want to mix, or to the middle if you want to scratch.
