Hercules control DJ...
Hercules control DJ steel driver for linux
3 Users
Hi everyone, I've been trying to install the drivers for the DJ Control Steel on Ubuntu 24.04 without success. Has anyone done this before, or does anyone know the correct procedure? I couldn't find anything on the official website, and the libraries I found online haven't worked.
You can also use this command to install a program that lets you run .exe files on Linux. (sudo apt install wine) !!! This should download a package that lets you run Windows EXE files on Linux; however, some similar packages may offer a 64-bit version, while others often only support the 32-bit version, but it should definitely work on Linux. Best regards, Baumi. (The command for Linux is in parentheses.)
  • wine
    wine64
    libraries
    audio support
    graphics support
    sometimes 32-bit packages
Hi Loro,
I am not a Linux user, and I no longer have a Steel controller, so I cannot do any test on my side..
DJ Control Steel was not USB Midi compliant, so the controls need a driver.
Someone here (in 2010) said in the following discussion he had made drivers https://forum.ubuntu-fr.org/viewtopic.php?id=400339
The driver page is there https://slist.lilotux.net/linux/deejay/mixxx/
