[Feature Request] C...
[Feature Request] Customizable Number of Cues for "Auto Hot Cue" Analysis
Hardware Setup:
  • Controller: Hercules DJControl Inpulse 200 MK3 / 4-Pad Controllers
Feature Summary
Add an option in DJUCED settings to choose the number of cues generated when using Auto Hot Cue (e.g., set to 2, 4, or 8 cues) instead of defaulting to 8 cues automatically.
Current Behavior vs. Desired Behavior
  • Current Behavior: When using the Auto Hot Cue feature during track analysis or prep, DJUCED automatically populates all 8 Cue slots.
  • Desired Behavior: A setting under Settings > Track Analysis / Library allowing users to select how many cues Auto Hot Cue generates (e.g., Max 2, Max 4, or Max 8).
Use Cases & Value
  1. Optimized for 4-Pad Controllers: Controllers like the Hercules DJControl Inpulse 200 MK3 have 4 physical pads per deck. Populating 8 cues creates clutter on pads 5–8 that require bank/layer switching to access or clear.
  2. Cleaner Library & Waveform View: Generating fewer, key structural markers (like Intro, Main Drop, Outro) keeps the waveform cleaner and avoids unnecessary marker clutter.
  3. Faster Preparation Workflow: DJs don't have to spend extra time manually deleting extra cue points (Pads 5–8) that they won't use during a set.
Thank you for considering this improvement for DJUCED!
Topic Tags
