the browser encoders of my T7 are starting to jump and I would like to replace them.
Does anybody know which parts those are? I mean the encoders to browse and load tracks.
Thanks in advance
Hello DJ_Kalle_Vornia,
DJControl Inpulse T7 browser encoders are Alps EC11E156445G, you may order replacement units from Hercules Technical Support
In Hercules support, the reference of this encoder is 6001578.
Thanks for the information. I cannot login to the Hercules support site since weeks, because the captcha is not working. I tried with several browsers and computers.
Hello CHRGIF,
If the captcha prevents you from login on https://support.hercules.com, please check your cookie settings:
https://community.hercules.com/community/general-discussion/pass-captcha-on-support-hercules-com/
