Using the Hercules ...
[Closed] Using the Hercules 200 XLR with wireless Headphones
4 Users
Hello there, since i am using a Logitech Lightspeed G733, which is a wireless Headset using a USB-Dongle - is there any way to use this with the Hercules 200 XLR and still control the audio? I dont want to give up the luxury of using wireless headphones just to be able to control every audio layer. As far as i know the Hercules 100 would be able to this.
Thank you in advance!
In the Windows sound settings, more precisely in the settings where you can set the level of micros etc. There you have to switch on monitoring for Creator Channel and route this to your headset.
CraftyDeluxe Topic starter 23/04/2024 10:13 am
Well i tried that and got it to work after windows kind of blocked access. So far so good! But i can hear the microphone now too in my headphones, how can i seprate them from the creator-mix?
I have the same problem with my bluetooth headphones. How to make bluetooth headphones work with the stream 200XLR? Thanks
Icône de validation par la communauté
You can go in the advance audio setting of window, Record
Click on Creator and Properties
Click on Listen
Select your wireless headphone ouput
Check the box Listen this peripheral
Then you should hear all Creator Mix to your Headphone.
Listen to Microphone through a Playback Device in Windows | Tutorials (tenforums.com)
