I hear sound from master in my headphones
I have problem to preview tracks on deck cos I hear also Master sound in headphones, can't find Out what is wrong. I installed drivers, avdio settings are correct. I am using djuced on Windows 10, Intel core i3, help!
Hi KristijanFrank,
If you hear the master in headphones while the key labelled MASTER below headphones volume knob, is not lit on
and if it occurs in DJUCED, the most likely reason is that your Windows has probably an audio virtualisation setting enabled.
The solution is then to select in DJUCED > Settings > Audio the audio Device "DJControl Inpulse 200 ASIO (ASIO)" instead of the WASAPI device.
I have 2 options to choose in audio settings:
1. Speakers (2-DJControl Inpulse 200Mk2)
2. Speakers/Headphones (Realtek High Definition Audio.
There is no Asio. Any idea?
Hello KristijanFrank,
If you see no ASIO, then you have not installed Hercules DJ drivers on your computer: please install the driver package from
https://support.hercules.com/en/product/djcontrolinpulse200-en/
For Windows 10, you should install the drivers package 2023_HDJS_2.
I reinstall drivers and problem gone
