Need calibration Guide for Inpulse 500
22 Users
3 Reactions
as some of my EQ knobs don't match with the knobs position shown in DJUCED f.e., i want to try to recalibrate them. AFAIK there is a guide how to do it. Can someone please send me the guide?
Thanx!
This topic was modified 2 years ago by AZ
Hello I would need the calibration guide for my inpulse 500, also because my mid and high knobs when set to it's default are turned almost all the way up. This has happend both for deck 1 and 2 and also the gain for deck 2 has the same issue.
Thanks in advance, Dorijan.
Hello Kidor,
I have just sent you e message with the link of the calibration guide.
You can find the message when you log on the forum or, in your profile, when you click on Messages tab.
Hello, I am also experiencing the issue with the 12 o'clock positions of some of my pots are slightly to the left and right. Could I kindly have the calibration guide please?
Hello Slax,
I have answered you in a private message.
You can read your private messages in going on your profile page and clicking in the "Messages" tab.
The link to download the pdf guide lasts 7 days.
PS: I now transfer files on fromsmash.com website instead of wetransfer because
- wetransfer has reduced to 3 days the time the transfered files remain online,
- while fromsmash keeps the files available for 7 days.
Please let me know if you meet any problem to download files from fromsmash.
  • Necesito la guia de calibración tambien ya que me falla mi fader de volumen izquierdo por favor
Hello. My EQ knobs are jittering randomly during the mix. This calibration guide can fix it? Can someone send it to me please?
Thanks
Hello Zeff,
Welcome to the forum.
If your DJ controller's knobs jitter (move virtually by themselves while you do not touch the physical knobs), you cannot run the calibration process as the jittering will prevent from ending the calibration.
You should post a message to the technical support on https://support.hercules.com/en/contact-en/
Hello Nivek,
I had posted an answer for you last week on
https://community.hercules.com/community/djcontrol-inpulse-500/manually-replace-volume-fader-on-inpulse-500/#post-27451
If you did not see my answer, it shows why forum ask to remain in the discussion where you post your first message.
So please answer my questions in that discussion:
1) write the name of your DJ controller: is it DJControl Inpulse 500,
2) describe which fader is not working properly, and describe how it behaves: what you see on screen, in which software.
If you cannot answer to these questions on the forum, you can contact Hercules technical support directly on https://support.hercules.com/en/contact-en/
I would also need the calibration guide for my inpulse 500 controller. I use Windows 10.
Reason: filer knobs default position is already applying filter or FX. Also randomly jumps around (Fiter/FX down or up).
Hello MG Freezy,
Welcome to the user community area.
I can send you the calibration guide (which may fix the default position issue - I suppose you mean the Filter center position on the screen with Djuced does not fit with the actual center position of the rotary knob), but your description of random jumps lets me believe there is jitter on the knob itself and if there is jitter, the calibration process cannot be completed.
Anyway, trying to run the calibration in that conditions is not dangerous (jitter may block the calibration process at a intermediary step, but it will not damage anything) so please look at your profile page, and click on the enveloppe icon to read my mail with the 7-day link to download the calibration guide.
Dear Hercules support,
I would also require the calibration guide for my Inpulse 500 controller. Several knobs are misaligned.
Thanks in advance!
I would also like the calibration guide.  Mainly because the pitch control center lock area is massive. Meaning the center pitch O area is not true 0, its a whole +.2 /-.2 in each direction, where moving the pitch slightly does nothing from the 0 lock area.  movement does not register until out of that +.2 /-.2 area.   This is like this in each dj software....  Djuced, Serato Lite, and Traktor 3. There has to be a way to reduce the pitch center like to a true 0 point only. I would like a fix for this and hope the calibration guide will help.
Hello James,
Welcome to the community area and happy new year.
I have sent you a private message you can read on your account page in clicking on the enveloppe icon.
Hi, i would also require the calibration guide for my Inpulse 500 controller. Several knobs are misaligned.
Thanks in advance!
Hola tengo los knobs de filtro y frecuencia media descalibrados.
Me haría falta la guía para recalibrarlos, gracias
Page 2 / 3
